Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 2011 KK (Liberty) CEL - Need Advice
  1. #11
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    27,692
    Are you getting those leak down specs from the service manual or from instructions that came with the tester? 30-44% seems high to me.
    As far as your compression numbers, those seem close enough to not worry about IMO.
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  2. #12
    Nothing but a Thing sipafz's Avatar
    Join Date
    Mar 2015
    Location
    Saukville, Wisconsin
    Posts
    2,449
    I donít know what the actual specs are yet. Iím just going by the gage. Like I mentioned, I was having issues with the gage due to how cold my garage is. Iím going redo the test on a warmer day which may led to the gauge reading differently.
    Iím encouraged by that I couldnít hear or see any glaring problem. I started it up this morning and the CEL remained off.
  3. #13
    Join Date
    Mar 2015
    Location
    Posts
    2,449
    Update: After a week of the harshest weather this season, I was cautiously optimistic that the plug wires were the issue. No CEL during the stretch of -30 temps. Unfortunately as the temps got closer to freezing the CEL came back on, P0302. I took a look and as I was moving around the new plug wires I noticed a manifold bolt/stud with a wire route clip rotate. Not just the clip, but the whole stud rotated. I tightened it back to 105 in/lbs and checked all the other bolts. I found that the bolt next in line was also loose and as luck would have it these loose bolts were by cylinder 2 & 4. I have no idea how those bolts would come loose as I have never touched them in the past. Anyway, those are tight and will see if that makes a difference. Maybe a vacuum leaking was happening during cold start and improved as the engine warmed?
    I got my bottle of BG44K and added it to the fuel system. I plan repeating the leak down test in a few weeks and hope this stuff helps the minor leak on the #6 intake valve.
    New complaint from the wife is that the heat is blowing cool on the drivers side and hot on the passenger side. Iím going to flush the heater core today. 3 more years and Iíll be happy to let this Jeep go in trade for a new JLU or JT
Similar Threads
  1. WA - Liberty Run Saturday Sept 3rd
    By wetfootnw in forum Trails & Upcoming Trips
    Last Post: 09-22-2016, 05:30 AM
  2. WA - Liberty Run May 17th
    Last Post: 05-15-2015, 04:51 AM
  3. Jeep Liberty
    By VinceB in forum General Jeep Stuff
    Last Post: 02-06-2015, 05:05 PM
  4. Jeep Liberty
    Last Post: 02-05-2015, 07:11 PM
  5. It used to be a liberty
    By cevery in forum Jeep Show & Tell
    Last Post: 03-12-2013, 11:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
