Just took mine off and it’s a pain. Twist them back and forth for a while then sit on the console with a foot on each floor board and pull, like you’ve never pulled, and they will pop off
I've been trying to get this of for days. I'm starting to get highly frustrated. Any tips on removing? I've followed directions from other threads but have gotten nowhere.
Sure would, I’ll cut mine in half so you can see the insides, as soon as I get them back
If it’s the same as my ‘15 it is ridiculously easy compared to my ‘09. Just pop the compression fitting down (it’s on the bottom of the knob). The knob itself will then come off with a good tug. In my ‘09, removing the shifter was almost a guaranteed black eye.
To be clear, the bottom piece of the knob needs to be slid down the shaft before you try to pull the main part of the knob off of the shaft.
Yea I just changed mine, just take a screw driver and pry down the bottom half, then wiggle the top part off. Took a little force but came off fairly easy...mine is a 2013 as well
Yeah the black eye thing is no joke on the older models. I have had to pull mine a few times. I found if you put a wrench that just fits the shaft under it and give it a good upward smack with a dead blow it pops off pretty easy.
This thing is being absolutely awful. I'm thinking about just gripping it with vice grips and yanking, but I'm honesty scared about damaging the shifter itself ( yanking and tugging on the tenant)
