Results 1 to 6 of 6
Thread: Carb question
  1. #1
    Fresh Catch jlarson's Avatar
    Feb 2018
    US
    6
    Carb question
    I have an 89 4.2...im wanting to change to the motorcraft carb...i have one that i think came off a 360...looks like a 3 barrel...the side is marked with 1.21...another is marked 1.23..question is....can i use either of them...maybe change the jets or something???20180311_164258.jpg 20180305_162836.jpg
    Sent from my SM-N950U using WAYALIFE mobile app
  2. #2
    Feb 2018
    US
    6
    I guess not
  3. #3
    Been Around the Block
    Oct 2016
    Illinois
    312
    a/s/l?
  4. #4
    Knows a Thing or Two BABOOZLE's Avatar
    Apr 2015
    Washington
    923
    It depends on the CFM. If they are both 2 barrels then they are probably similar. The 360 is larger so it might be slightly bigger. You won’t know the CFM until you look up the part numbers on the inter webs. Are the base plates the same? If the new one bolts onto the manifold and the butterflies cycle freely then you may be able to pull it off. Won’t know until you try.
  5. #5
    Fresh Catch
    Feb 2013
    NW Pennsyvania
    3
    Motorcraft
    Many people use the 1.21. I put a 1.53 on my 4.2. Check the jets you my be ok. If it is off of a 360 engine you will probably have to change them to a smaller size. There is a web sight I believe is called Mikes Carburetor. There is a wealth of information there. There is contact information there as well. That is who I got my Jets from.
  6. #6
    Feb 2018
    US
    6
    Thank you
Similar Threads
  1. Resurrecting a Carter YS Carb
    By M38A1Driver in forum Old Iron Classic Jeeps
    Last Post: 07-27-2017, 02:47 AM
  2. 2012 Cold air intake with PSC and CARB
    By kyleolson in forum Jeep JK Wrangler
    Last Post: 04-17-2015, 07:56 PM
  3. 1985 cj7 carb which screw is which?
    By Limpinlobster in forum Old Iron Classic Jeeps
    Last Post: 12-13-2014, 08:42 AM
  4. Question about 2.8 V6 carb...
    By Grumpiebill in forum Jeep JT Scrambler Truck
    Last Post: 03-14-2014, 02:26 AM
  5. CARB rules can't sell tuners in California???
    By jkjurny in forum Jeep JK Wrangler
    Last Post: 02-28-2013, 03:32 AM
