Page 11 of 11 FirstFirst ... 91011
Results 101 to 107 of 107
Thread: The Build and Adventures of Bearbait
  1. #101
    Nothing but a Thing sipafz's Avatar
    Mar 2015
    Saukville, Wisconsin
    1,838
    Quote Originally Posted by Jsouder53 View Post
    What is the easiest way to figure out bumpstop size needed?
    One thing that I just realized I’ll be needing to do is bumpstops... with the RC shocks, they were internal on the shocks so I never had to mess with them.
    Nice upgrade with the gears and stuff!
    A good place to start is lift = bump extension length.
    From there, you can make adjustments to allow maximum up travel to keep the tires from rubbing the inner fenders and shocks from bottoming out.
  2. #102
    Nothing but a Thing Jsouder53's Avatar
    Aug 2017
    Gallatin Gateway, Montana
    1,244
    Quote Originally Posted by sipafz View Post
    Thank you!
  3. #103
    Aug 2017
    1,244
    I’m looking at the evo bumpstops, I have a 3.5 inch lift (yields a little higher I think) should I go with a 3 inch or 4 inch bumpstop
    Edit: just found Clayton Off Road bumpstops, trim able
  4. #104
    Nothing but a Thing Mybadjk's Avatar
    Dec 2016
    Elko
    1,636
    I think 3” is recommended for 37s and 4” is recommended for 40s. I believe most 3” lifts come with 3” bumps
  5. #105
    Aug 2017
    1,244
    Quote Originally Posted by Mybadjk View Post
    Cool! Thank you for that
  6. #106
    Old Timer VeruGE*144's Avatar
    Feb 2017
    Illinois, Chicago
    3,294
    I run 4” Evo coils, that actually give me exactly 4” of lift on my JKU. I run winch up front and end up with a slight rake but once loaded up with tools and gear for trail running, it levels out. I run 37s with trimmed flares. Not sure what size my bumps are but, it stops my tires about 3/8” from rubbing on my cut flares at full stuff and are long enough not to bottom out my shocks .
    One tip I have for measuring bumps is to pretend the rubber factory stops in the frame are not even even there. Measure form the metal perch where they insert into the frame, to the bump you are adding on the axle. Those rubber bumps will smush all the way down in certain situations. Compare that measurement to how much up travel you have left in your shocks.
  7. #107
    Aug 2017
    1,244
    Quote Originally Posted by VeruGE*144 View Post
    Thank you for that knowledge! I will definitely do that just ordered some bumpstops that you can trim down
Similar Threads
  1. Build and Adventures of Cpt. Price.
    By Xhisors in forum Jeep Builds
    Last Post: 04-23-2018, 04:47 AM
  2. The Adventures of ROBnTANK
    By ROBnTANK in forum Upcoming Trips & Events
    Last Post: 08-14-2017, 02:07 AM
  3. The adventures of Barry Blue
    By Ginz in forum Jeep Builds
    Last Post: 07-12-2016, 06:45 AM
  4. EVO Chase 12 Build for Ultimate Adventures
    By piginajeep in forum Jeep Builds
    Last Post: 06-19-2013, 01:25 AM
