Page 9 of 9 FirstFirst ... 789
Results 81 to 86 of 86
Thread: PSC Big Bore XD? Yes or NO?
  1. #81
    Fresh Catch
    Join Date
    Sep 2015
    Location
    Bentonville, AR
    Posts
    28
    Quote Originally Posted by SLO View Post
    So I just learned that Bruiser Conversionsí LS kit allows for the Big Bore box but Motechís doesnít leave room for it for some reason. So, Iíll be doing the PSC hydro-assist kit but my gear box will just be rebuilt and ported...I wonít have the option to go with the XDII box being that Iím doing the Motech LS kit. My understanding is that the hydro-assist takes a lot of stress off the sector shaft so I should be ok but not ideal. Also, there will be less torque output not having the XD box.
    What are most of you guys running with 40ís? Should I worry about doing hydro-assist without the XD box?
    SLO -- I think there is room for an XDII box in a Motech conversion. I have the Motech kit with an LC9. Planning on installing and XDII in a few months. The shop doing the work does a lot of XD installs and they measured out that it would fit. Don't know about the 6.0 dimensions.
  2. #82
    Hooked SLO's Avatar
    Join Date
    Jul 2016
    Location
    Portland, OR
    Posts
    181
    Quote Originally Posted by rogerk93 View Post
    I know for it to clear you have to shave down the psc big bore and the alternate very little where they contact each other for it to clear. Thatís the instruction from bruiser.
    I wonder if Motech has tried that and opted against it for some reason. Iíll have to ask.
  3. #83
    Hooked SLO's Avatar
    Join Date
    Jul 2016
    Location
    Portland, OR
    Posts
    181
    Quote Originally Posted by BaddestCross View Post
    A larger cylinder, cooler, and hi-flow pump should be more than enough for 40s.
    Thanks. I was hoping/assuming that to be the case.
    Quote Originally Posted by Cubewarrior View Post
    I have the L94...not sure if thatís part of it. Or, I wonder if Robbie just hasnít figured it out yet or hasnít really tried where others have. Iíll probably just leave it as is until I have an issue.
  4. #84
    Old Timer BaddestCross's Avatar
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    4,764
    Take that with a grain of salt since it's coming from a guy running a Redneck Ram setup. I have the smaller cylinder, factory gear box, and factory pump with no cooler that turns my 37s with ease. However, with the research I did before going with what I've got, you shouldn't have any issues.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  5. #85
    Advertiser Exodus Jeeps's Avatar
    Join Date
    Feb 2015
    Location
    Texas
    Posts
    2,519
    Itís because we use the Jeep accessories and ďothersĒ donít. The ac compressor lands right next to the steering gear, VERY close. Youíll be fine with a regular box and hydro assist.
  6. #86
    Hooked SLO's Avatar
    Join Date
    Jul 2016
    Location
    Portland, OR
    Posts
    181
    Quote Originally Posted by Exodus Jeeps View Post
    Thanks Bubba!
Similar Threads
  1. Psc Big bore
    By rogerk93 in forum Jeep JK Wrangler
    Last Post: 09-02-2018, 12:54 AM
  2. Hydro Assist vs Big Bore XD Box
    By ZachJKUR in forum Jeep JK Wrangler
    Last Post: 05-26-2017, 03:41 AM
  3. big bore xd question
    By steep-n-deep in forum Jeep JK Wrangler
    Last Post: 04-07-2017, 05:08 PM
  4. AEV Pintler center bore
    By Jackal01 in forum Wheels & Tires
    Last Post: 03-28-2016, 08:42 PM
  5. Center bore
    By badassbrass in forum Jeep JK Wrangler
    Last Post: 05-22-2013, 06:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
