Results 1 to 5 of 5
Thread: Front and Rear Seals and Oil Pan Gasket Replacement
  1. #1
    Join Date
    Jan 2018
    Location
    Alpharetta, GA
    Posts
    55
    I have an oil leak dripping off the front transmission housing and rear of oil pan.
    I also have basically a wet bottom front of the engine, dripping/slinging onto everything.
    This screams front and rear seals, correct?
    Any idea what I can expect to pay to have both replaced? How big of a hurry should I be in to have this done?
    ‘90 YJ 4.2
    Thanks for looking.
  2. #2
    Hooked PT1400's Avatar
    Join Date
    Dec 2016
    Location
    Eugene, Oregon
    Posts
    158
    I don't know the entire cost, as I work on my own stuff. Yes, both of the seals are worn. For the front you're looking at the seal AND the balancer needing to be replaced. Save yourself the head ache. As far as the rear main is concerned, not only is the seal bad but judging by the age (you didn't put a rough milage in your post) the crankshaft will most likely be worn as well. You might get lucky by replacing the rear main seal but it might get worse. Could go either way. Hold off on the oil pan gasket until after you do the seals. It may not be part of the issue.
    Keep us posted on what you find.
  3. #3
    Fresh Catch FLJeepTJ97's Avatar
    Join Date
    Mar 2018
    Location
    Florida
    Posts
    5
    Don’t forget to consider the intake manifold gasket. That can also present as a rear main seal leak. I replaced my rear main seal when I had dripping from the transmission by the inspection plate. Was certain was the rear main. Replaced it and still leaked. Upon further inspection, found it leaking from the top. Changed the intake gasket and solved the problem.
  4. #4
    Join Date
    Dec 2016
    Location
    Eugene, Oregon
    Posts
    158
    If you have oil leaking from your intake gasket, you've got other problems. Valve guide seals, stuck open pcv valve, etc.
    Start with the basics. If you've still got leaks, then start looking elsewhere.
  5. #5
    Join Date
    Mar 2018
    Location
    Florida
    Posts
    5
    So far so good. Maybe I just got lucky. No other issues.
Similar Threads
  1. Front inner axle seals
    By DKjeep in forum Jeep JK Wrangler
    Last Post: 07-05-2016, 02:57 AM
  2. Need advice -- changing seals (again) on my front axle
    By Cubewarrior in forum Jeep JK Wrangler
    Last Post: 05-02-2016, 02:59 AM
  3. Inner Front Axle Seals on Dana 30
    By chttrbx in forum Jeep JK Wrangler
    Last Post: 02-11-2016, 07:05 PM
  4. 30/40 front axle seals
    By 2007blackJk in forum FOR SALE (Active Members ONLY)
    Last Post: 09-16-2014, 10:43 AM
  5. DS replacement Front and Rear
    By Dashyl in forum Jeep JK Wrangler
    Last Post: 02-09-2014, 06:11 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
