2018 MOAB Easter Jeep Safari MOPAR CONCEPT JEEP PICS!!
WOOHOO!! FCA just released the very first photos of the 7 Mopar Concept Vehicles that they'll be bringing out with them to the 2018 Moab Easter Jeep Safari! Give them a look now and let us know what you think! :yup:
Jeep 4SPEED
Light, quick and nimble, the Jeep 4SPEED concept is the latest in a line of lightweight Easter Jeep Safari concepts. Built “4SPEED,” this latest lightweight concept, following the popular Pork Chop concept in 2011 and Stitch concept in 2013, bolsters Wrangler’s off-road capability and performance through extensive weight savings, and showcases the all-new 2.0-liter turbocharged I-4 engine.
On the exterior, the Jeep 4SPEED concept features custom weight saving measures including a carbon fiber hood, high-clearance carbon fiber fender flares and a carbon fiber rear tub with perforated aluminum panels. The 4SPEED concept boasts a sleek side profile courtesy of a raked windshield, elongated door openings and an aggressively swept back custom cage. The rear of the concept utilizes custom, lightweight bodywork, and because of the combined weight savings, 4SPEED’s ride height is two inches higher than a stock Wrangler.
In addition to being lightweight, overall length has been shortened by 22 inches while leaving the wheelbase at its stock length, resulting in increased approach and departure angles.
For even more capability, Jeep 4SPEED features Dana 44 front and rear axles with a 4.10 gear ratio and 18-inch lightweight monoblock wheels wrapped in 35-inch BF Goodrich Mud Terrain tires.
The interior features a customized instrument panel, and re-trimmed front seats, while the rear seats have been removed and a welding curtain has been repurposed as a bikini top. The floor has been bedlined and the foot wells have been replaced with perforated aluminum panels.
The Jeep 4SPEED is powered by a 2.0-liter I-4 turbocharged engine, mated to an eight-speed automatic transmission.
Jeep Sandstorm
Inspired by Baja desert racers, the Jeep Sandstorm concept is all about blitzing long, sandy straightaways while still being capable of handling the daily driving duties. To accomplish this, the Sandstorm features off-road hardware that will handle both with ease, including an extreme-duty suspension system and a powertrain with excess power on tap.
To fit the Baja look, the exterior features custom styling cues including a vented carbon fiber hood, vented high clearance front and rear fender flares and a cage that includes a rear mounted lay down style spare tire carrier. The exterior handles and swing gate have been removed while the rear doors have been chopped for a cleaner look.
Other custom Baja-inspired touches include high clearance front and rear tube bumpers, modified rock rails, an integrated on-board air compressor, race-style fuel filler, KC Carbon series front auxiliary lights and a chase light.
The front axle has been moved forward four inches and utilizes a heavy-duty longarm four-link suspension and track bar. The rear axle has been moved back two inches and utilizes a triangulated trailing arm four-link suspension. The longer wheelbase allows for increased high-speed stability. Custom coilovers and bypass shocks allow the front wheels to travel 14 inches while the rear wheels can travel up to 18 inches.
For even more capability, the Jeep Sandstorm concept includes heavy-duty front and rear Dynatrac 60 axles with a 5.68 gear ratio, 17-inch beadlock wheels and 39.5-inch BF Goodrich Krawler tires.
The Baja race truck theme continues throughout the interior, which features a custom cage that integrates the chassis, leather-trimmed front seats and unique low-back racing bucket seats in the rear. A racing-inspired cluster and 7-inch off-road GPS unit handle navigation while independent rocker switches control on-board electronics, air compressor and axle lockers. The Sandstorm concept sheds all plastic trim and carpet in favor of a bedlined floor.
The Jeep Sandstorm is powered by a 6.4-liter V-8 engine from the Mopar performance catalog and is mated to a six-speed manual transmission.
Jeep B-Ute
The Jeep B-Ute concept is equipped with a variety of Jeep Performance Parts for the ultimate off-road adventure.
The Jeep B-Ute’s exterior features unique front and rear fascias and upper grille area, a hood with heat extractors, and wider flares.
Jeep Performance Parts featured on the B-Ute concept include a 1.5-inch lift kit, a roof rack and rock rails. The Jeep B-Ute’s off-road capabilities are increased by using 17-inch wheels with a 30-millimeter offset, wrapped in BF Goodrich T/A Baja Champion tires.
Inside, the B-Ute features custom trimmed seats with Mineral inserts, a Carbonite finish on the shifter, speaker and vent surrounds, Piano Black inserts, a MOLLE system on the back of the front seats, and Mopar all-weather floor mats.
The Jeep B-Ute is powered by a 2.4-liter Tigershark engine, mated to a nine-speed automatic transmission.
Jeep Wagoneer Roadtrip
The Jeep Wagoneer Roadtrip stirs up nostalgic memories of going to Yellowstone National Park on a summer family vacation. This particular Wagoneer retains its heritage and charm as it continues to utilize its original steel body, while the chassis and drivetrain have been updated.
The wheelbase has been stretched five inches, and the body has been updated to accept the additional length, a wider track and custom fender flares. Other subtle exterior styling tweaks include reshaped wheel wells, bumpers and integrated rock rails. A razor grille freshens the look up front, while Bottle Green architectural glass replaces the original pieces.
The Wagoneer’s off-road capability has been bolstered courtesy of a boxed and reinforced frame, Dana 44 front and rear axles with lockers, four-link suspension with coilover springs, and 17-inch steel wheels wrapped in 33-inch BF Goodrich Mud-Terrain tires.
Inside, the Wagoneer features original front and rear bench seats, door panels, kick and rear panels, all trimmed in Oxblood-colored leather. A wicker headliner gives the Wagoneer an open, lighter feel and the floor has been bedlined. Additional interior details include a custom cooler fashioned from period-correct luggage, and a tool box created from the valve cover of this Wagoneer’s original 230 Tornado OHC-6 engine.
Known as the original luxury 4x4, this 1965 Jeep Wagoneer is rich with heritage and is built to scale the trails of Moab or cruise the vast highways of the western states. Built from 1963 to 1991, the Wagoneer was the first four-wheel-drive vehicle mated to an automatic transmission, pioneering the first modern SUV. The classic Jeep Wagoneer is a beloved icon and continues to enjoy a robust following of enthusiasts worldwide.
The Jeep Wagoneer heritage vehicle is powered by a 5.7-liter V-8 and is mated to a four-speed automatic transmission.
Nacho Jeep
The Nacho Jeep serves as a rolling catalog loaded with selections from the Mopar brand’s Jeep Performance Parts (JPP) menu, offering a blueprint off-roaders can follow to create their own custom trail vehicle.
Before a single part or accessory is added, this 2018 Jeep Wrangler Rubicon already stands out thanks to the rare Nacho yellow color. Jeep Performance Parts featured on the Nacho concept include a brawny hood that is accented with the standard black hood graphic featuring the all-new JPP badge, which is engineered to accommodate a cold-air intake that feeds the 2.0-liter turbocharged I-4 engine. The satin black Mopar grille adds contrast to the Nacho exterior, and the sturdy steel Rubicon bumper offers off-road protection and functionality, and includes a Warn Winch kit.
Superior trail visibility, inspired by the Jeep Luminator concept vehicle shown at Moab in 2017, is delivered by A-pillar and brush guard-mounted LED lights from the Automotive Lighting division of Magneti Marelli, that mount via JPP brackets. Automotive Lighting LED header lights seal to the windshield for extra forward illumination, and a rear off-road scouting light uses four-color LEDs to communicate trail conditions: stop (red), 1-3 miles per hour (amber), 3-25 mph (green) and a rear flood light (white).
A 2-inch lift kit elevates the Nacho concept for increased off-road clearance and includes new 2.5-inch diameter aluminum body shocks. Oversized 37-inch tires wrap around 17-inch beadlock-capable wheels, and a satin-carbon finish on the wheels is the sole conceptual touch on the Nacho concept. The beadlock trim rings are finished in high-gloss back and secured with cadmium-plated bolts. Other Jeep Performance Parts include rock rails that are thicker and wider to protect the exterior and carry a grippier coating similar to that used on Ram Truck bedliners, 2-inch-round tube doors, and grab handles embossed with the iconic Jeep grille logo to assist in vehicle ingress.
The spare tire tailgate hinge reinforcement provides a rock-solid foundation for a spare tire carrier that mounts to the tailgate with strength enough to handle 37-inch tires. A JPP fuel door in black finish completes the exterior.
Off-road performance is achieved without sacrificing premium interior appointments. Black Katzkin leather seats are dressed up with the Jeep grille logo embroidered in light tungsten stitching on seatbacks, and light tungsten accent stitching on the seat bolsters.
Jeep Jeepster
Available Jeep Performance Parts concept modifications combine to bring to life the Jeep Jeepster concept. Based on a Wrangler Rubicon, this concept evokes the color palette and speedy styling of the 1966 Jeepster.
The original’s classic two-tone graphic theme is mirrored on its modern-day counterpart with a Firecracker Red body, set off by a Bright White concept hardtop, chopped by two inches, and a Bright White custom windshield raked back 2.5 degrees to create a cropped, compact appearance. The customized windshield maintains the all-new Wrangler’s convenient fold-down feature. Bright White also accents the perimeter of the Rubicon fender flares, and an upper portion of the concept half doors. Jeep badging is replaced with a tri-color Jeepster hard badge.
The Jeepster deftly balances concept possibilities with a range of presently available Jeep Performance Parts, including a JPP hood and graphic, without the optional cold-air intake or snorkel. LED off-road lights in 5- and 7-inch applications illuminate the trail for the Jeepster, shining bright at up to 8,000 lumens. The LED lights are mounted to the A-pillar via light brackets. The Rubicon steel bumper features premium production LED fog lamps.
A 2-inch lift kit and 2.5-inch diameter aluminum body shocks work with oversized, 37-inch BF Goodrich KO2 tires to raise the Jeepster above off-road obstacles. Beadlock-capable 17-inch wheels are accented by body-color matching Firecracker Red beadlock trim rings. Additional items from the JPP portfolio include a black fuel door, grab handles and all-weather floor mats.
Inside the Jeepster, a concept tubular roll cage replaces the sport bar and an additional 38-inch tire is secured with a custom in-cabin spare tire carrier. The interior meshes off-road functionality with premium features, including black Katzkin leather seats with Rubicon Red Jeep grille logos embroidered on the seatbacks, and Rubicon Red accent stitching on the seat bolsters. The instrument panel inserts are Firecracker Red to tie in with the exterior.
Relocation of the spare tire to the cabin provides an opportunity for another custom touch: concept storage packs mounted to the tailgate for transport of gear and supplies such as food, water and tools. The packs feature a split design to accommodate the rearview camera. A concept rock step — a unique combination of a rock rail/side step — completes the Jeepster.
Jeep J-Wagon
The Jeep J-Wagon concept is personalized with Jeep Performance Parts to create a premium-styled vehicle equally at home on the trails and urban cityscapes.
Starting as a Wrangler Sahara, the J-Wagon is painted a conceptual Warm Neutral Grey with warm-tinted glass, and complemented with subtle Brass Monkey touches throughout the exterior. The J-Wagon features a version of the JPP hood designed with a cutout kit to work with the available snorkel, an appropriate choice for the sealed-cabin style of the vehicle. The hood latch is Brass Monkey and further embellished with a black Willys logo.
For hardcore off-roaders, new 5-inch LED lights mount with JPP brackets to deliver commercial and military grade illumination. That trail detail is balanced with the street-appeal of a Mopar black grille pulled from a Wrangler Rubicon, and features body-color matching bezel trim. The premium Sahara bumper aligns with the vehicle’s color pattern via Brass Monkey fog lamp bezels. The J-Wagon concept also features 17-inch slot-design wheels that are also finished in Brass Monkey, a treatment chosen after receiving positive feedback in a sneak peek at the 2017 SEMA Show.
Black metal concept rock sliders guard the J-Wagon’s exterior, and a matching black metal concept JPP roof rack offers utility and functionality to fit any lifestyle. A black JPP fuel door and Orange Crush accents on the Jeep badge and tow hooks add style points. A spare 35-inch KM3 BF Goodrich tire mounts to the spare tire tailgate hinge reinforcement, and includes the JPP Center High-Mount Stop Light (CHMSL) light relocation kit.
Premium appointments are the story inside. Camel-color Katzkin leather seats give an elite feel and feature stark brown piping and plow-through inserts that mimic the triangulated grille design of the concept rock rails. Eye-level Brass Monkey trim and bezel accents on the HVAC vents, door handles and steering wheel harmonize the interior with the exterior.
sipafz
The Wagoneer is my favorite too! The Sandstorm and Jeepster are nice also. I was hoping to see a truck more like the Crew Chief of years past.
Franck
the whole suspension of the Sandstorm is built by EVO with KING shocks, adding to that : what a Badass look ! ... i would buy this baby anytime ! :D
the 4speed reminds me of the one you guys built some years ago with Mel for the family of your friend ;)
jorgelrod
That sandstorm is a beast, funny how they choose Dynatrac and not Mopar UD60s when they need To build performance vehicles. And still some people try to put them on the same level.
Sessoms14X
The Jeepster is definitely my favorite. I think a red 2 door JL will be in my future for sure. The Sandstorm is cool as well. Kind of a good idea of what the truck will look like.
Sent from my SM-G955U using WAYALIFE mobile app
jeeeep
Looking forward to seeing those up .
Wagoneer and Jeepster my favorites...well all are but I would buy the Wagonee or Jeepster :thumb:
