Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
Thread: TORQUE SPECS : JL WRANGLER Reference Guide
  1. #21
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,576
    REAR SUSPENSION
    Description Nm Ft. Lbs. In. Lbs. Comments
    Lower control arm front bolts 100 + 50 74 + 50 -
    Lower control arm rear nut 100 + 50 74 + 50 -
    Shock absorber upper bolt 110 81 -
    Shock absorber lower nut 100 74 -
    Stabilizer bar bolts 63 46 -
    Stabilier bar link upper nut 90 66 -
    Stabilizer bar link lower nut 80 59 -
    Track bar nut (frame end) 100 + 30 74 + 30 -
    Track bar bolt (axle end) 100 + 60 74 + 60 -
    Upper control arm front bolt 100 + 80 74 + 80 -
    Upper control arm rear nut 100 + 65 74 + 65 -
  2. #22
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,576
    RESTRAINTS
    B-Pillar impact sensor nut 9 - 80
    Clockspring mounting screw 6 - 53
    Driver airbag to steering wheel bolts 9 - 80
    Front turning loop height adjuster mounting bolts 45 33 -
    Front impact sensor nut 11 8 -
    Front seat belt buckle bolt 40 30 -
    Front retractor pretentioner bolt 45 33 -
    Front retractor pretentioner bracket to B-Pillar bolts 26 19 -
    Front retractor to B-Pillar bolt 45 33 -
    Front seat belt turning loop mounting nut 39 29 -
    Occupant restraint controller mounting nut 11 8 -
    Passenger airbag mounting bolts 18 13 -
    Seat airbag mounting nut 10 7 -
    Rear center retractor to seat frame bolt 70 52 -
    Rear center retractor to floor bolt 70 52 -
    Rear retractor to C-Pillar bolt 32 24 -
    Rear retractor belt to floor nut 48 35 -
    Rear seat belt buckle to floor bolt 70 52 -
    Rear seat belt buckle to seat frame nut 40 30 -
    Rear turning loop to sport bar 32 24 -
  3. #23
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,576
    STEERING COLUMN
    Steering wheel nut 50 37 -
    Steering column nuts 27 20 -
    Intermediate shaft coupler pinch bolts 54 40 - Do NOT reuse
    these fasteners.
    If removed, a
    NEW fastener
    MUST be installed
    and tightened to
    specifications.
  4. #24
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,576
    STEERING GEAR
    Adjuster screw lock nut 45 33 -
    Power steering gear bolts 133 99 -
    Power steering gear pitman shaft nut 250 184 -
    Power steering gear pressure line 28 21 -
    Power steering gear return line 28 21 -
  5. #25
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,576
    STEERING LINKAGE
    Drag link inner nut (at pitman arm) 105 77 -
    Drag link outer nut (at steering knuckle) 64 47 -
    Drag link adjuster clamp 46 34 -
    Tie rod end nut (at steering knuckles) 64 47 -
    Tie rod end adjuster clamp 46 34 -
    Steering damper bolt (at axle) 80 59 -
    Steering damper nut (at tie rod) 80 59 -
    Steering damper bracket nut 75 55 -
  6. #26
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,576
    STEERING PUMP
    Power steering pump bracket to frame 28 21 -
    Power steering pump to bracket 8 6 71
    Pressure line to pump 20 15 -
    Power steering hose routing bracket bolt 6 5 53
    Power steering fluid reservoir bolt 6 5 53
  7. #27
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,576
    TRANSFER CASE - FULL TIME (Selec Track)
    Poppet plug 20 15 -
    Drain/fill plug 28 21 -
    Case half bolts 26 19 -
    Output flange nut 225 166 -
    Transfer case to transmission bolts 60 44 -
    Shift motor (actuator) bolts 12 9 -
    Range position switch 27 20 -
    Extension housing bolts 26 19 -
    Range lever bolt 30 22 -
  8. #28
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,576
    TRANSFER CASE - PART TIME
    Poppet plug 20 15 -
  9. #29
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,576
    TIRES & WHEELS
    Spare tire carrier lug nut 80 59 -
    Tire pressure sensor nut 1.4 - 12
    Spare tire carrier bolt 17.5 13 -
    Lug Nut/Bolt Torque **Lug Nut/Bolt Size Lug Nut/Bolt Socket Size
    130 Ft-Lbs (176 Nm) M14 x 1.5 22mm
  10. #30
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,576
    TRANSMISSION - AUTOMATIC
    Engine to bell-housing bolt 60 44 -
    Extension housing to transmission bolt 27 20 -
    Manual park release lever shaft nut 10 - 89
    Manual park release cable to transmission 20 15 -
    Manual park release grommet to bracket 9 - 79
    Manual park release lever to transmission shaft 20 15 -
    Manual park release shield to transmission 17 12 -
    Output shaft flange nut 60 44 -
    Output speed sensor bolt 8 - 71
    Park pawl lock rod guide plate bolt 10 - 89
    Park pawl shaft plug 35 26 -
    Shifter assembly bolts 9 - 79
    Transmission oil pan bolt 10 - 89
    Transmission oil pan drain plug 9 - 80
    Transmission oil fill plug 35 26 -
    Transmission oil pump housing to cover bolt 5 + 45 - 44 + 45
    Torque converter to flex plate bolt 55 41 - Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specifications.
    NOTE: If old fastener must be reused, Loc-Tite must be applied to the threads.
    Transmission mount to adapater 30 22 -
    Shift lever assembly to floor pan bolts 8 - 70
    Transmission shift knob 2 - 17
    Transfer case shift knob 2 - 17
    Manual park release to shift lever assembly 8 - 70
Similar Threads
  1. Torque specs on grade 8 bolts
    By Mike_JK_Houston_711 in forum Jeep JK Wrangler
    Last Post: 02-05-2017, 06:40 PM
  2. Jk torque specs
    By LarryG in forum Jeep JK Wrangler
    Last Post: 10-13-2016, 02:05 PM
  3. Oil pan bolt torque specs
    By webejeepin in forum Jeep JK Wrangler
    Last Post: 01-10-2016, 09:45 PM
  4. Torque specs on these two bolts ..
    By Dopey84 in forum Jeep JK Wrangler
    Last Post: 12-08-2015, 07:22 PM
  5. Torque specs
    By JeepinLife in forum Jeep JK Wrangler
    Last Post: 10-02-2013, 02:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
wayoflife is a moniker that Ive been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
