Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Negative camber
  1. #21
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    29,873
    Quote Originally Posted by Glen1978 View Post
    Your camber is pretty high as well. Spec is like 4.2 or somewhere around there.
    You can’t adjust camber.
    2012 Dozer JK
    -Dynatrac PR44/Rubicon Rear
    -Nitto 37” Trail Grapplers
    -Rock Krawler 2.5” Lift
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    2012 Billet Silver JKUR
    -EVO DTD front and rear
    -Dynatrac PR60/PR80
    -EVO High Clearance Long Arm
    -Nitto 40” Trail grapplers
    -KMC Machetes
    -JE Reel 1410/1350 Driveshafts
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  2. #22
    Fresh Catch
    Join Date
    Apr 2019
    Location
    CO
    Posts
    4
    Quote Originally Posted by A.J. View Post
    The camber isn't really all that bad. Caster has a .4 deg split which could contribute to your pull. I agree the adjustable parts can make the alignment guy look good on the print out, but tend to "adjust" themselves off road and usually cause more problems. I would just run it and rotate often. Every 3-5000 miles including the spare tire WAYALIFE mobile app
    Thanks, The mechanic may have blown it out of proportion, he made it seem like it was going to devastate the axles and tires over time. My big problem here is that I just bought this used Rubicon from a dealership. It doesn't pull, no wobbles, drives great, but I just wanted to get it checked out and have a pre-trail torque on the suspension. Turns out I should not have trusted the dealership to have done any inspection!
  3. #23
    Old Timer fiend's Avatar
    Join Date
    May 2017
    Location
    SoCal
    Posts
    3,144
    Quote Originally Posted by OverlanderJK View Post
  4. #24
    Knows a Thing or Two A.J.'s Avatar
    Join Date
    Jun 2015
    Location
    Grants Pass Or.
    Posts
    780
    Quote Originally Posted by fiend View Post
    Compression shims do exist. I hate them but they do exist.
  5. #25
    Join Date
    May 2017
    Location
    SoCal
    Posts
    3,144
    Why do you hate them? I understand it’s preferable to have a straight axle housing, but for someone with $25 and not $1000, what’s wrong with the shims?
  6. #26
    Nothing but a Thing jdofmemi's Avatar
    Join Date
    Mar 2018
    Location
    Menifee CA
    Posts
    1,622
    I'm curious as well, why these would be a bad idea. It seems like a way to stretch the life of a housing while saving money for better axles
    There is also 1 degree offset ball joints, but I'm not sure about those. I have heard good and bad reviews. One shop I know pushes them, and claims good results.
  7. #27
    Nothing but a Thing QuicksilverJK's Avatar
    Join Date
    Apr 2016
    Location
    Reno NV
    Posts
    1,398
    I have seen the offset ball joints, but never seen the shims before. Never seen them used in an off-road application, but have heard of good results from a buddy that is a steering and suspension specialist.
    Obviously having a straight, non bent axle would be the better option though.
  8. #28
    Join Date
    Jun 2015
    Location
    Grants Pass Or.
    Posts
    780
    I have used them on the rear of front wheel drive cars some. They are a pain in the ass to do because you have to remove the wheel,caliper, hub bolts, axle nut etc. etc. to install and every time you want to make an adjustment. Not to mention you no longer have a flat flush mating surface so you should re torque the hub bolts after awhile too. If you have to use them I wouldn't go more that .50 deg. Mostly just a time consuming PITA for not much gain in my opinion.
  9. #29
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    29,873
    Well technically that would be changing it and not adjusting it.
    2012 Dozer JK
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    -Dynatrac PR60/PR80
    -KMC Machetes
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  10. #30
    Join Date
    May 2017
    Location
    SoCal
    Posts
    3,144
    Sound like a lawyer.
Similar Threads
  1. Camber
    By YJslim in forum Jeep TJ & YJ Wrangler
    Last Post: 01-06-2018, 02:33 AM
  2. Tyre size Negative Effects ?
    By Jaquesdp88 in forum Jeep JK Wrangler
    Last Post: 02-25-2017, 10:50 PM
  3. Negative pressure when i turn the air up.
    By mojave5 in forum Jeep JK Wrangler
    Last Post: 09-08-2016, 08:58 PM
  4. Trying to track down negative camber on passenger side
    By Hammmerhead in forum Jeep JK Wrangler
    Last Post: 03-18-2016, 04:50 AM
  5. Negative effects of not re-gearing soon enough?
    By LAJK in forum Jeep JK Wrangler
    Last Post: 03-11-2016, 04:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
