TJ / LJ Solid Axle Ind HP60 rear
deantac
Rear axle is a Solid Axle Ind...
60.5 width and 1.25 spidertrax spacers = 63"
Drilled for 4.5" and 5.5" bolt pattern
ARB Diff
5:13
35 spline superior alloy 4340 ...Semi Float axles
Willwood brakes
1310 yoke
Never Broke anything or replaced any parts on this also.
Need upper control arm mounts and lower shock mounts to bolt into a stock TJ. I had Nth degree rear stinger set up with outboard shocks, LJ length.
$ 2000.00
California City, CA....93505 pick up only, no shipping.
deantac
Not to bad yet, it was 97 the other day. Cooler this week, The wind is a problem trying to work on my Jeep.
