Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Body kit for 1976 CJ5
  1. #1
    Fresh Catch
    May 2018
    CO
    36
    Question Body kit for 1976 CJ5
    Hello-
    New to the forum and just picked up a rough 1976 CJ5... Going to do a frame off restoration and thinking I am going to need to just bite the bullet and buy all new- Body Tub- Fenders- Hood etc.
    Wonder if anyone can direct me to best quality and place to purchase. Thank you!
  2. #2
    Nothing but a Thing AZ Explorer's Avatar
    Feb 2017
    San Tan Valley, AZ
    1,947
    As I understand it, the Willys overland tub is a fully modified MD Juan tub that will bolt right on with all the little defects corrected. It is not cheap.
    MD Juan is the only manufacturer I know of manufacturing classic steel jeep tubs. Omix Ada sells an unmodified tub if you have the skills to make the corrections yourself. Otherwise, scour the internet and see if you can find a used/clean one, or there is always fiberglass if that is not a problem for you.
  3. #3
    Fresh Catch
    May 2018
    CO
    36
    Appreciate the info... yeah going to have this jeep in the family for a long time so not afraid to spend a little to get it right. I will check out the MD Juan products.
  4. #4
    Nothing but a Thing TOPLESS's Avatar
    Mar 2015
    Benton Harbor, Michigan
    1,284
    Way cool! Love those 5’s! You thinking keeping it original or mild build?
  5. #5
    Fresh Catch
    May 2018
    CO
    36
    Post
    Quote Originally Posted by TOPLESS View Post
    Yeah always been partial to the CJ5's... going to keep it as original as possible... has 7.50 x16 tires on it now and kinda like that old school look as well.
    Everything is there.... just the Body tub and other metal parts are toast so going to spend the money to make it all new again.
  6. #6
    Knows a Thing or Two holliewood61's Avatar
    Mar 2015
    Peterstown Wv
    525
    If you're willing to pony up the cash, and want it to last, the aqualu aluminum tubs are the way to go.
    Sent from my LGUS997 using WAYALIFE mobile app
    Beat it to fit, paint it to match
    08 WK
    00 WJ
    99 TJ
    81 CJ7
    60 CJ5
    Best wheeling in WV
    http://trailsheaven.com/Plan-Your-TR...vy-Branch.aspx
  7. #7
    Fresh Catch
    May 2018
    CO
    36
    Post
    Yeah after looking thru my options and what might be best for me / easy application.... Going with the Repli-Tubs from Willy’s Overland Motors.
    Really like the idea of all the modification they do on site there and once delivered will be a direct bolt on having all the extra fabrication work needed/completed by them.
    Should work out good.
    Starting the tear down now to start peeling things back to see whats good and bad... Should be pretty straight forward project.
  8. #8
    Addict wjtstudios's Avatar
    Nov 2016
    Rochester, MI.
    6,297
    It’s started! Congrats on the rebuild!
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
  9. #9
    Fresh Catch
    May 2018
    CO
    36
    Post
    Thanks- feels good to have this project started
    I do have a question... The engine is definitely sitting at an angle... higher in front. Is this right/pretty normal and the way it should be?
  10. #10
    Nothing but a Thing Strodinator's Avatar
    Apr 2017
    Oregon
    1,183
    Quote Originally Posted by gfrench View Post
    That is fairly normal. It's all relative to how the frame curves right there. A slight gradient is pretty standard for what I've seen.
    Sent from my PH-1 using WAYALIFE mobile app
    If you want to see a broke college kid struggle through an LS swap, then here's your chance: https://wayalife.com/showthread.php/...546#post956546
Similar Threads
  1. Replies: 18
    Last Post: 11-26-2017, 11:53 PM
  2. Any difference between 2007-11 body and 2012+ body?
    By 2nd.gunman in forum Jeep JK Wrangler
    Last Post: 01-04-2016, 11:03 AM
  3. Under Body Armor
    By bdmckenna in forum Jeep JK Wrangler
    Last Post: 04-21-2013, 12:40 AM
  4. 1'' jk body lift
    By esbyrd in forum Wanted (Active Members ONLY)
    Last Post: 03-14-2013, 05:26 PM
  5. Any body tried this?
    By DINKELROC in forum Jeep JK Wrangler
    Last Post: 02-27-2013, 05:56 PM
