Results 1 to 10 of 10
Thread: Crank But No start
  1. #1
    Caught the Bug Rubi_the_jeep's Avatar
    Join Date
    Feb 2017
    Location
    US
    Posts
    73
    Crank But No start
    Hey guys i have run into a problem with my 2000 4.0L TJ. I was off roading with my buddies and the jeep was working perfectly fine. We even stopped at a spot I turn the Jeep off, and went to start it back up and it started fine. Then we got to our campsite. And I turned it off and played music from the jeep while in accessory. But then about 30 minutes later I went back to start the jeep and it just kept cranking. Not starting. I had plenty of volts from the battery, and I did not seem like it was not getting fuel. I happen to have a fuel pressure gauge and I checked the pressure and I was not getting any fuel pressure when trying to start. So we towed it back home and put a new fuel pump on it. And it still cranks but does not start. Replaced the spark plugs, and that did nothing. It’s not the ECU because I had another one lying around that still worked I put that on the jeep and it still does not start. Any help is appreciated thank you very much!!
  2. #2
    Nothing but a Thing 19YJ94's Avatar
    Join Date
    Jul 2017
    Location
    Indiana
    Posts
    1,163
    Did you change the fuel filter? Check all the wire connections, grounds, ect?
  3. #3
    Join Date
    Feb 2017
    Location
    US
    Posts
    73
    The fuel filter is attached to the Bottom of the fuel pump correct?
  4. #4
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    29,525
    Make sure pump is getting power and ground. You will only have power there for about 3 seconds. Once the system pressurizes, power signal goes away. Swapping the relay is a quick check too.
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  5. #5
    Nothing but a Thing Zstairlessone's Avatar
    Join Date
    Dec 2012
    Location
    Texas
    Posts
    1,087
    Sure you have gas?
  6. #6
    Addict jesse3638's Avatar
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,758
    Did the TJ have the same security system issues the XJ did?
  7. #7
    Join Date
    Jul 2017
    Location
    Indiana
    Posts
    1,163
    Quote Originally Posted by Rubi_the_jeep View Post
    Yeah I believe your right, I was thinking of my YJ 4.0.
  8. #8
    Join Date
    Feb 2017
    Location
    US
    Posts
    73
    Quote Originally Posted by WJCO View Post
    Yeah i hear the pump coming on when i first turn the key to accessory. I’ll try switching the relay
  9. #9
    Join Date
    Feb 2017
    Location
    US
    Posts
    73
    Quote Originally Posted by Zstairlessone View Post
    Sure you have gas?
    Yeah i have a break in the fuel line and it is definitely pressurized
  10. #10
    Hooked PT1400's Avatar
    Join Date
    Dec 2016
    Location
    Eugene, Oregon
    Posts
    158
    You said you had plenty of volts but what were the volts while cranking? The PCM shuts down below 9.6 volts.
Similar Threads
  1. Replaced clutch no crank
    By Zach1215 in forum The 8th Slot
    Last Post: 05-07-2017, 01:11 PM
  2. Smart start with Mopar OEM remote start
    By Pyro1415 in forum Jeep JK Wrangler
    Last Post: 12-14-2016, 11:52 PM
  3. 2013 Won't crank
    By Baker in forum Jeep JK Wrangler
    Last Post: 11-17-2016, 05:20 PM
  4. Crank shaft seal leak
    By Dopey84 in forum Jeep JK Wrangler
    Last Post: 09-03-2015, 06:43 PM
  5. Crank sensor
    By Greg in forum Jeep JK Wrangler
    Last Post: 06-14-2013, 03:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
