Strodinator
Having worked in sales for Napa for two plus years I can tell you how Limited the catalogs by application are. O'Reilly's, AutoZone, Carquest, and Napa all list parts for the most part by vehicle application and struggle to use proper keywords to find parts that may actually fit your vehicle. The system that most parts houses use often are based on the TAMS operating system, or total automotive management system, and sucks for finding this obvious parts by application. If you are in a store and are getting frustrated because the counter person cannot find what you believe is a basic part see if he or she can find a Dorman part number to cross back into the system. A vast majority of Parts houses carry a Dorman line that, other than different part numbers, are exact Dorman parts repackaged and renumbered. Napa equivalent line is called Dorman Solutions and the only difference is the first few numbers of the part number. I can't tell you how many times I have found a part number for a customer in the past few months alone by completely ditching the vehicle application parameters and doing a quick Google search to find relevant Dorman parts for the specific vehicle. Any competent counterman should be able to do this and cross the number back into their system and more often than not they will find the part number is not only in the system, but also in stock. I know one issue I have with parts houses such as Napa (even though I work for them) is that a lot of the parts that break easily or need repair are not listed by application and instead reside in these discrete part lines such as Napa solution line. Always make sure your counterman does everything to cross back in part numbers especially FCA numbers as well as a Dorman because I have found Dorman part numbers to be fairly bulletproof when trying to find a part for a customer. And as an added bonus, any of you in the Portland / Hillsboro area who come into the Hillsboro on Napa, just ask for me and I'll see what I can do to get you a solid discount. I'll be glad to answer any questions for you guys as I have my own Napa Prolink account and I have no problem being a resource for you to find parts. I'm about 4 beers into the night now so cheers
Sent from my PH-1 using WAYALIFE mobile app
