Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: 40ís on a PR44?
  1. #21
    Old Timer VeruGE*144's Avatar
    Join Date
    Feb 2017
    Location
    Illinois, Chicago
    Posts
    3,631
    Quote Originally Posted by fiend View Post
    It can be done, but is tricky because the pumpkin is cast while the tubes are not. You need to find an experienced welder who knows how to properly preheat the cast metal and also how to get the two parts to cool in such a way that they donít crack (metal contracts as it cools). The shop that fixed my friendís axle is a 90 minute drive, so I canít just pop over there.
    Also, I think to be safe youíd want to remove your carrier, locker wiring, and maybe even the pinion gear and seals before welding, so they donít all get cooked. Thatís gonna add several hundred dollars in labor unless you find a welder whoíll let you do all that work yourself in his shop. Unlikely.
    Damn, sounds like a ton of work. Would be great to have it done though. Thanks for the info..... maybe one day.
  2. #22
    Addict jesse3638's Avatar
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,391
    Yep. Now heís got me paranoid about spinning my diff with 37s.
    Quote Originally Posted by VeruGE*144 View Post
    Canít you weld it in before hand, might save you some headache. Now I am paranoid too, thanks a lot guys
    Just go easy on the skinny pedal and you'll be just fine. When in doubt, throttle out is not the best of mottos to follow..
  3. #23
    Been Around the Block sm31's Avatar
    Join Date
    Nov 2012
    Location
    Eagle River, AK
    Posts
    282
    Im sorry! It looks like my ham fisted self managed to delete my post when I was trying to edit it.
    I had a question about the Pro Grips... the front rotors, at 13.5" are slightly smaller than the rears, at 14.25". Is this due to limited space, or are there other concerns?
    And I apologize again for the hi-jack!
  4. #24
    Nothing but a Thing Bear_JKU's Avatar
    Join Date
    Aug 2017
    Location
    New Mexico
    Posts
    1,503
    Quote Originally Posted by sm31 View Post
    Just guessing, but maybe it is to give more braking surface so the rear brakes can grip a little more to avoid nose dives in a hard braking situation and allows for more even braking.
Similar Threads
  1. PR44 installed!!!
    By chili84 in forum Jeep JK Wrangler
    Last Post: 02-21-2016, 06:17 PM
  2. Getting a PR44 but...
    By jorgelrod in forum Jeep JK Wrangler
    Last Post: 03-17-2015, 05:54 PM
  3. D44 vs PR44
    By RedRubicon17 in forum Jeep JK Wrangler
    Last Post: 02-24-2014, 10:23 PM
  4. 40s on a PR44
    By desertrunner in forum Jeep JK Wrangler
    Last Post: 04-13-2013, 02:48 AM
  5. What's the diff D44-PR44-PR44/60hybrid-PR60
    By JAGS in forum Jeep JK Wrangler
    Last Post: 12-13-2012, 12:55 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
