Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Vehicle Jerks when hitting the gas
  1. #11
    Caught the Bug The.Ernie's Avatar
    May 2018
    Memphis
    50
    UPDATE: I was driving, everything was fine at first as usual. Then as I was driving the engine started sputtering again and I held down the gas but it was not accelerating at allll, it also smells like dead fish or coffee beans in here but it might be just where Iím at. Not 100% sure. But yea I floored it and Iím not getting above 15 mph and I popped the hood open and manually pressed the throttle body and it still did the same thing. Itís a v6 but it shook like crazy and sounded like only 3 or 2 cylinders were firing correctly
  2. #12
    Old Timer BaddestCross's Avatar
    Aug 2016
    Palmdale, CA
    3,591
    Quote Originally Posted by The.Ernie View Post
    Bad catalytic converter
    Build Thread: Adventures with Fiona
    '08 JKR Rescue Green 2-Door
  3. #13
    Knows a Thing or Two Bear_JKU's Avatar
    Aug 2017
    New Mexico
    837
    Bad catalytic converter would be the cause of the smell. You have a v6 in your TJ?
  4. #14
    Caught the Bug Whitarmy's Avatar
    Aug 2017
    Texas
    60
    I had bad O2 sensors on the driver side that kept making me misfire while driving. Originally thought the same things as you. I got a code that led me to check them though. Swapped them out and it was all good again. This was at 70k miles
  5. #15
    Knows a Thing or Two Snboarder113's Avatar
    Oct 2015
    michigan
    871
    If it smelt like bad eggs itís a clogged cat for sure.
  6. #16
    Knows a Thing or Two Zstairlessone's Avatar
    Dec 2012
    Texas
    836
    Quote Originally Posted by Snboarder113 View Post
    Yep, and to prevent it never feed your cat pastrami sandwiches and cheese
  7. #17
    May 2018
    Memphis
    50
    Quote Originally Posted by Bear_JKU View Post
    Yes itís a v6
  8. #18
    May 2018
    Memphis
    50
    Quote Originally Posted by Whitarmy View Post
    Sweet
Similar Threads
  1. Spring hitting frame?
    By medic_23387 in forum General Off-Road Tech
    Last Post: 05-09-2017, 10:23 PM
  2. Tie rod hitting diff
    By brooklyn4x4 in forum Jeep JK Wrangler
    Last Post: 03-22-2016, 01:51 AM
  3. Jeep jerks when turning
    By sassmouth in forum Jeep JK Wrangler
    Last Post: 07-16-2015, 03:50 PM
  4. Hitting puberty
    By Sporadic in forum Jeep Show & Tell
    Last Post: 03-16-2013, 11:32 AM
  5. Anthem to the jerks
    By bl17z90 in forum The 8th Slot
    Last Post: 12-29-2012, 01:40 PM
