Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Strong gas fumes when tank is full
  1. #1
    Fresh Catch
    Join Date
    Apr 2018
    Location
    Goshen, Indiana
    Posts
    8
    My ‘16 JKU stinks up my garage with strong gas fumes when my tank is filled. No puddles of gas on the floor or sign of leaks. Any idea what would cause this ? The fumes subside after the tank is three quarters full or less. Thanks !
  2. #2
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    28,356
    Light a match and the leak will be quite obvious.
    (Just kidding to be politically correct in today's internet world so I don't get sued. )
    Check your charcoal canister and purge valve.
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  3. #3
    Fresh Catch
    Join Date
    Jul 2018
    Location
    Idaho Springs, Colorado
    Posts
    4
    Quote Originally Posted by 2jeeps4me View Post
    When you fill up, do you let it stop on its own and call it good, or do you day F it and top it off to max? i have buddies whoe shake their trucks trying to get all the air bubbles out when filling up haha not my idea
  4. #4
    Caught the Bug Eloucha's Avatar
    Join Date
    Oct 2017
    Location
    Ohio
    Posts
    96
    Same here if u figure it out. Plz let me know. Only when I fill it up.
  5. #5
    Been Around the Block Gobicon2017's Avatar
    Join Date
    Oct 2017
    Location
    Corpus Christi , Tx
    Posts
    456
    I believe there is a thread on this somewhere. I remember some we’re having issues with the filler hose. Hope that helps.
    Gobicon 2017 JKU Recon build
    https://wayalife.com/showthread.php?t=51738
  6. #6
    Fresh Catch
    Join Date
    Apr 2018
    Location
    Goshen, Indiana
    Posts
    8
    Thanks, I ‘ll look it up !
  7. #7
    Fresh Catch
    Join Date
    Aug 2018
    Location
    TENNESSEE
    Posts
    1
    Fuel smell when tank is full
    Had the same problem on a 2007 jk Sahara we purchased recently, after ruling out all evap lines for leaks with a smoke machine, I dropped the fuel tank and found that the smell was coming from cracks in the fuel pump mounting flange. Replaced with new fuel pump assembly and problem solved.
    Attached Images Attached Images
  8. #8
    Nothing but a Thing
    Join Date
    Oct 2015
    Location
    dontcare
    Posts
    1,590
    Still under warranty? I'd have the dealer find it. They have the magic smoke machine for the evap system. I wouldn't mess around with fuel fumes.
  9. #9
    Fresh Catch GeoWillys's Avatar
    Join Date
    Apr 2017
    Location
    Ohio
    Posts
    27
    I have a 15 jk Willys and had that problem. Since I have an extended warranty I took it to the dealership and they found there was an issue where the filler neck connects to tank. Don't remember what was exactly wrong but they ordered a part and installed it. No more gas fumes.
  10. #10
    Addict Brute's Avatar
    Join Date
    Nov 2015
    Location
    HI & WA
    Posts
    7,344
    I had a leak at where the wire for the sending unit enters the tank...also check the evap lines
Similar Threads
  1. The Kool-Aid is Strong Over Here
    By jkwebbie in forum The INFIRMARY
    Last Post: 06-25-2018, 09:12 PM
  2. Replies: 84
    Last Post: 10-16-2017, 11:56 PM
  3. 30000 strong
    By 2014siljk in forum Give us a Wave
    Last Post: 01-16-2017, 04:48 AM
  4. 4.0L still going strong
    By Gadget in forum General Jeep Stuff
    Last Post: 01-12-2017, 06:57 PM
  5. Gasoline fumes in garage after full tank.
    By OIFvet in forum Jeep JK Wrangler
    Last Post: 07-08-2016, 06:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
