Results 1 to 2 of 2
Thread: Steering
  1. #1
    Fresh Catch
    Jul 2018
    CA
    12
    Steering
    Xj has steering problems I have to rev it up to get power steering to kick in not sure if pump is bad or just have air in it any solutions?
  2. #2
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    28,092
    Quote Originally Posted by Xjproject417 View Post
    With fluid full, turn the steering wheel back and forth 4 or 5 times to bleed air out. Any leak in the system can continue to suck air in though. Also, check belt tension. If belt is slipping, that will create the same symptom as a failing pump. If all of that is ruled out, it's probably a bad pump.
Similar Threads
  1. Steering
    By Djeep20 in forum Jeep JK Wrangler
    Last Post: 07-03-2017, 05:56 PM
  2. Steering
    Last Post: 06-23-2017, 01:30 PM
  3. Steering...again
    By 132JKPNW in forum Jeep JK Wrangler
    Last Post: 12-22-2016, 01:53 AM
  4. Steering stabilizer with PR44 and Synergy Steering
    By troy-bilt in forum Jeep JK Wrangler
    Last Post: 02-01-2016, 09:31 PM
  5. Steering Slippage/Bump Steering Problems
    By NAUXJ in forum Jeep JK Wrangler
    Last Post: 10-12-2015, 11:56 PM
