Results 1 to 4 of 4
Thread: Switch-Pro Help
  1. #1
    Fresh Catch
    Jun 2018
    Arizona
    3
    Switch-Pro Help
    Hello. I have a 2018 TH and just received a Switch-Pro SP9100 switch panel. It is similar to a SPOD. I need to locate a light input (parking light or side marker wire), an ignition or ignition accessory input/wire , and a high beam, reverse light, or dome light signal/wire. Can anyone assist me with locating the ignition or ignition accessory wire and where to locate the high beam or reverse light wires? I have a led light bar on the roof, 2 light pods at the rear license plate bracket, and rock lights to install and connect to the Switch-Pro panel. I am OK when it comes to some installing add ons.
    I was quoted 1100.00 to have everything installed and really dont want to spend that much. Thank you for your time.
    Attached Images Attached Images
  2. #2
    Living the WAYALIFE JAGS's Avatar
    Aug 2012
    SoCal
    11,054
    Give switch pros a call. They are very helpful. Might be able to give you some pointers. $1100 is nuts!!
    I think I may consider lifting my Jeep. Or not.
    The Evolution of ENVY
  3. #3
    Caught the Bug Good2Go's Avatar
    Sep 2017
    Phoenix, Arizona
    76
    There’s a lot of info out there on installing these in JK’s, but maybe not so much in a Renegade so giving them a call is a good idea.
    If you haven’t done a lot of wiring before, a Switch-Pro is a do-able task and a good learning experience.
    I highly recommend doing this yourself.
    Then go out and reward yourself by spending the $500 you saved on something else you really want!
  4. #4
    Fresh Catch
    Jun 2018
    Arizona
    3
    Thank you for the advice. I'll call Switch-Pro later today and see if they can help. 👍
Similar Threads
  1. Switch-Pros SP8100 Switch Panel Demo Video
    By Switch-Pros in forum Jeep JK Wrangler
    Last Post: 07-07-2015, 08:50 PM
  2. Switch-Pros switches mounted to Daystar dash switch panel?
    By jared181920 in forum Jeep JK Wrangler
    Last Post: 05-13-2015, 03:55 AM
  3. Replies: 30
    Last Post: 01-14-2015, 05:45 AM
  4. toggle switch on daystar switch panel?
    By brizon85 in forum General Off-Road Tech
    Last Post: 10-12-2013, 10:58 PM
