Stillmacrae
Horn Not working (clock spring, wire harness TIPM replaced) UPDATE/FIXED
So I've seen a lot of these post up and about on different forums but I'm looking for advice. I have a 2018 Rubicon Recon. Problems started probably within the first 3 months of owning the Jeep. I noticed that the Horn would not function, then I noticed that the steering wheel radio buttons would not function (volume, station channel) also the Uconnect buttons would not work, dash menu buttons (speedometer, tire pressure etc switch). The cruise control buttons still work. Jeep went to the dealer, they told me it was the clock spring, they replaced it and driving away I discovered the problem was still not fixed. I took the jeep back and after working on it they told me it was the wiring harness that went to the steering wheel and after replacing it and assuring me everything was working correctly I picked up the jeep, this time tested it before leaving the lot, still didn't work. So on the third time I brought it back they told me I had a bad TIPM unit but that it was on back order and they'd let me know when it came in. About a month later I got a call, they replaced the TIPM unit and again as soon as I got the Jeep I tested the controls and horn (which they assured me were working) and it still was not working. When the problem first started it was intermittent. After the jeep sat a while (overnight) it would not work... but after driving it for a bit the horn and volume switches would start functioning again. The problem has been getting worse though and now it hasn't worked for the past 3 weeks. The guys at the dealer say they are at a loss and don't know what the problem is. Any help or suggestions would be appreciated. Oh also the horn DOES still function... meaning if you hit the panic button the horn goes off. If you lock the jeep with the key fob the horn will go off, but it doesn't work when pressing the horn.
