Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: 99 TJ 4.0 cranks but wont fire.
  1. #1
    Fresh Catch
    Join Date
    Sep 2018
    Location
    California
    Posts
    4
    Im about to toss in the towel. Ive done various testing and it has led to part replacements IE: new fuel pump/regulator, new spark plugs, new crank sensor.
    One morning I went to start my TJ and it kept cranking but not fully turning over and firing up. no matter what Ive done, the Jeep is consistently making the same sounds and doing the same thing as that first morning.
    Help please!
  2. #2
    Fresh Catch
    Join Date
    Sep 2018
    Location
    TX
    Posts
    27
    Kept cranking but not fully turning over? Does this mean it was turning over normal but not firing up? As opposed to cranking but turning over slowly? Take the battery and starter to autozone or the like and have them tested. If good come back to check spark..new plugs gapped properly and fuel pressure at the rail? Fuel pump running? Listen for it to prime up it normally just runs like 2 second when you turn the key on have someone turn it on you put your ear up to the fuel filler. If you have spark and fuel the next thing is compression or bad fuel. One of those missing maybe relay, fuse wiring or worse pcm. Any codes itís not running so check OBD or dash codes , that rule out the chance that you got bad parts. I had a fuel pump from Autozone that was dead took them 2 tries to get me a good one...donít give up you will learn from it and know your Jeep better good luck
    IF aint broke fix it until it is or you are!
  3. #3
    Fresh Catch
    Join Date
    Sep 2018
    Location
    TX
    Posts
    27
    *that...should be donít rule out
  4. #4
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    27,979
    Spark, fuel, compression.
    Has to be one of those 3. After replacing plugs, did you verify if you have spark at the plugs?
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  5. #5
    Fresh Catch
    Join Date
    Sep 2018
    Location
    California
    Posts
    4
    Quote Originally Posted by Shadowfire View Post
    NO CEL OR CODES.
    Initially I suspected it was fuel related so I tested the pressure at the fuel rail as well as a leak down test. Priming the fuel pump only brought it to 20 psi, and turning the key to try and start it brought it up to 40 psi but a leak down test revealed that it was losing pressure instantaneously and returned to zero within a couple minutes. So I replaced the whole entire assembly for the fuel pump as mentioned before. Upon replacing the pump/ regulator, I tested it again and my reading went to 45 upon priming and turning the key, and also there was no more leak down. (I didnt check the injectors because Ive had them in only for a few months and have periodically checked them from other builds while I had them off the engine and fuel rail. Theyre 12 hole bosch 24lb)
    So I moved on to spark. I pulled the plugs and to my surprise, number six had a broken prong so I suspect Ive been running on 5 cylinders for a while. The rest of the spark plugs were definitely fouled so I replaced them all and got a set of pregapped .035, and I double checked the gap before installing. Still, the same result as before, the starter was strong but it still wasnt getting the engine to fire up. (Ive been doing all this trouble shooting while jumping my Jeep because without successful starts it has been killing my battery)
    After that I just started poking around the internet. Moved on to the crank sensor, replaced it.. same thing. Did more internet poking (today), replaced the camshaft sensor, same result.
    So far nothing I have done has made ANY difference in the way the Jeep sounds, feels, or does. My results are the same as the morning I tried to start her up but couldnt.
  6. #6
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    27,979
    Quote Originally Posted by stevenmuck View Post
    NO CEL OR CODES.
    Check the wiring harness everywhere. Look for corrosion, rodent damage, etc. Sounds like pcm or wiring issue. Did this just randomly not start one day or did it die on you?
  7. #7
    Nothing but a Thing QuicksilverJK's Avatar
    Join Date
    Apr 2016
    Location
    Reno NV
    Posts
    1,402
    You said that you replaced the plugs, but did you verify that they are actually sparking?
  8. #8
    Fresh Catch
    Join Date
    Sep 2018
    Location
    California
    Posts
    4
    Quote Originally Posted by WJCO View Post
    Yes just randomly one morning is when this nightmare began.
  9. #9
    Fresh Catch
    Join Date
    Sep 2018
    Location
    California
    Posts
    4
    Quote Originally Posted by QuicksilverJK View Post
    I havent checked for spark yet. Ill do that tomorrow.
  10. #10
    Fresh Catch mntj91's Avatar
    Join Date
    Feb 2017
    Location
    Minnesota
    Posts
    18
    Iíd also suggest a good strong battery. Have you checked the coil? Engine grounds?
Similar Threads
  1. Coilovers wont go low enough
    By Jtmw in forum Jeep JK Wrangler
    Last Post: 10-07-2015, 05:18 PM
  2. 6 speed wont go into reverse
    By squigmang in forum Jeep JK Wrangler
    Last Post: 06-21-2014, 01:07 AM
  3. Replies: 277
    Last Post: 12-27-2013, 10:17 PM
  4. Replies: 1
    Last Post: 09-02-2013, 03:48 PM
  5. Poppet Flats Fire / Silver Fire / Silent Valley
    By Krieger in forum The 8th Slot
    Last Post: 08-08-2013, 04:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
