Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Steering Stabilizer Science?
  1. #1
    Join Date
    Jul 2018
    Location
    Colorado
    Posts
    175
    Iím sure youíve seen or heard someone talk about running anything from dual stabilizers to no stabilizer at all but have you seen a drag link relocation bracket for one? I only bring this up because I saw a video of a guy installing one that required his stabilizer to be mounted to the frame and connect on the drag link.
    So can someone explain the science behind the stock location on the tie rod? I understand what a stabilizer does but I always assumed it was connected to the tie rod to reduce feedback from both knuckle ends. Upon asking the individual his thoughts about the new location he stated that if you think about it the drag link is connected to a knuckle as well. While true itís also connected to the pitman arm so wouldnít that cause resistance in the steering? A stabilizer does require force to be applied in order to compress after all.
    Thoughts?
  2. #2
    Old Timer TrainWreck618's Avatar
    Join Date
    Oct 2015
    Location
    East of St. Louis
    Posts
    2,923
    I think itís just to get it out of the way so you donít smash yours up. Those stabilizers are in a bad spot to begin with and always seem to get hit
  3. #3
    Join Date
    Jul 2018
    Location
    Colorado
    Posts
    175
    Quote Originally Posted by TrainWreck618 View Post
    It doesnít seem like it would be nearly as effective though and compromise the steering wheel by creating additional resistance...
  4. #4
    Old Timer Clutch's Avatar
    Join Date
    Dec 2015
    Location
    STL metro
    Posts
    2,769
    I think thatís how the TJ mounted itís SS.
  5. #5
    Nothing but a Thing Gadget's Avatar
    Join Date
    Aug 2014
    Location
    Pennsylvania
    Posts
    2,261
    This^ , My 2014 JK is now on number four, finally put a relocation kit on to try and save this one.
  6. #6
    Nothing but a Thing Overland_stormtrooper's Avatar
    Join Date
    Aug 2016
    Location
    Tyler Texas
    Posts
    1,485
    While I've seen this cant say if it works or not as I havent had mine on for close to 2 yrs now
    Sent from my SM-G892A using WAYALIFE mobile app
  7. #7
    Knows a Thing or Two Clearskies's Avatar
    Join Date
    May 2017
    Location
    Pine Mountain Club US
    Posts
    921
    I did the Rock Krawler drag link flip with a replacement tie rod (Bent my Stock one) and that put the steering stabilizer on top of the tie rod almost perfectly level.
  8. #8
    Addict BaddestCross's Avatar
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,638
    The TJ has a y-link setup for it's steering. Haven't looked at it that closely, so I don't know how it differs. That being said, I don't have a flipped drag link or raised track bar but I did use a Rancho kit to place the stabilizer above and level with the tie rod to get it out of harm's way.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  9. #9
    Join Date
    Dec 2012
    Location
    Franklin, TN
    Posts
    160
    Yup, having a stabilizer is not a bad idea, it is just the stock location sucks and you end up damaging them if you wheel much (it really sucks when it is dented and it is hard to steer). The other issue is too many people trying to solve steering geometry and death wobble issues with a stabilizer. That is when silliness ensues. If you wheel a lot, get a relo kit or go without. I do not love the feel of not having a stabilizer, but I would only run a stock one (or at least I would not pay for more than stock)
    2017 White JK : (build thread)
    Synergy 3"/2", Dynatrack Trail Leader Package
    Dynatrac Pro Grip Kit, PSC Big Bore Steering Kit
    MCE Fenders, 10th Anniversary Hood, Borla Climber Exhaust
    ATX Slabs, Nitto Trail Grappler 37's
    Shrock Works Front Middy, LoD Destroyer Rear
    Genright Sliders, Warn VR12-S ,
    Oh yeah, and VENGEANCE.
  10. #10
    Nothing but a Thing 2nd.gunman's Avatar
    Join Date
    Nov 2015
    Location
    Brisbane, Australia
    Posts
    2,413
    The whole system moves together so I canít see any difference in operation. The stabiliser dampens oscillations thatís all
Similar Threads
  1. Replies: 33
    Last Post: 02-15-2016, 01:58 AM
  2. Steering stabilizer with PR44 and Synergy Steering
    By troy-bilt in forum Jeep JK Wrangler
    Last Post: 02-01-2016, 09:31 PM
  3. Steering stabilizer in 4WD mag
    By Mbair in forum Jeep JK Wrangler
    Last Post: 04-16-2015, 12:33 PM
  4. Steering Stabilizer
    By Devallee in forum Jeep JK Wrangler
    Last Post: 01-03-2014, 01:35 AM
  5. Fox ATS steering stabilizer
    By lbjeeper in forum Jeep JK Wrangler
    Last Post: 09-25-2013, 04:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
