Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: I need advise
  1. #1
    Fresh Catch RyanHanley's Avatar
    Join Date
    Aug 2015
    Location
    Colorado
    Posts
    41
    I need advise
    11/03/18 I was driving down the highway going 65-70 MPH and I start hearing this rattle so I pull over check to see if any heat shied is coming off or anything noticeable and I find nothing so I pull back onto the highway and get up to 65-70 and the front driveshaft snaps randomly I had northridge 4x4 here in Denver install my Evo long arm kit and they didn’t tighten my drive shaft bolts all the way so they came loose and caused a lot of damage should I have them fix everything that broke or how else would you guys go about this?IMG_1380.jpgIMG_1382.jpgIMG_1383.jpgIMG_1384.jpgIMG_1385.jpg
  2. #2
    Nothing but a Thing Speedy_RCW's Avatar
    Join Date
    Jul 2015
    Location
    Northern California
    Posts
    1,902
    If they fucked it up, they should fix it.
  3. #3
    Knows a Thing or Two RockinAZJK's Avatar
    Join Date
    May 2016
    Location
    Flagstaff, AZ
    Posts
    928
    Damn, well I’d certainly be taking it back to them. I had a similar go around (not as bad) with a shop in AZ: had my gears installed, went back for my break in fluid change and axle seal leak (for warranty) and my gears seized down the street from their shop when I left. Ended up making them rebuild my front driveshaft, replace from u-joints, and install a new OEM locker. I would think that Northridge would do the same for you
  4. #4
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    30,620
    Fuck that shit. I wouldn’t have them touch my rig after that. They suck. I would make them pay for that shit especially the tub.
    How long ago did they do it? I would also have someone check out the rest of their work.
    2012 Dozer JK
    -Dynatrac PR44/Rubicon Rear
    -Nitto 37” Trail Grapplers
    -Rock Krawler 2.5” Lift
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    2012 Billet Silver JKUR
    -EVO DTD front and rear
    -Dynatrac PR60/PR80
    -EVO High Clearance Long Arm
    -Nitto 40” Trail grapplers
    -KMC Machetes
    -JE Reel 1410/1350 Driveshafts
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  5. #5
    Fresh Catch saulmvv's Avatar
    Join Date
    Mar 2017
    Location
    AZ
    Posts
    47
    Rough man, It wouldn’t hurt to contact them. Hope they can help you out.
  6. #6
    Been Around the Block RSQCON's Avatar
    Join Date
    Oct 2016
    Location
    Utah
    Posts
    316
    Offroad Evolution installed my kit and my front driveshaft flange bolts came loose so do they suck also? Luckily for me it happened at slow speed off road. I'm guessing they properly installed the bolts and they worked themselves loose. I started checking mine regularly. A good way to check the driveshaft is to crawl under and push up on it.
  7. #7
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    30,620
    Quote Originally Posted by RSQCON View Post
    No driveshaft bolts don’t just work themselves loose if they are installed properly with locktite.
    2012 Dozer JK
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    -Dynatrac PR60/PR80
    -KMC Machetes
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  8. #8
    Join Date
    Aug 2015
    Location
    Colorado
    Posts
    41
    Quote Originally Posted by OverlanderJK View Post
    The long arms were installed 9/28 and they claim everything was perfect and I’ll be good to go for a long time so obviously when you hear something like that you think you’re good to go but finally It decided to snap yesterday and the tub is what really pisses me off lucky it didn’t crack the transfer case but it did snap the transfer case shift cable so they’re going to be replacing a lot of shit and fixing everything when I get to talk to them tomorrow definitely not happy and I know they don’t have the greatest rep on here and I won’t be returning to them after this is resolved
  9. #9
    Join Date
    Aug 2015
    Location
    Colorado
    Posts
    41
    If anyone on here is in Denver where do you guys get a lot of your work done?
  10. #10
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    30,620
    Quote Originally Posted by RyanHanley View Post
    I would have the transfer case pressure tested to be sure the case isn’t cracked anywhere. Doesn’t take much to crack those housings.
    2012 Dozer JK
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    -Dynatrac PR60/PR80
    -KMC Machetes
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
Similar Threads
  1. Real advise on 37's
    By gmanmp in forum Jeep JK Wrangler
    Last Post: 03-05-2017, 09:36 PM
  2. Next Mod Advise
    By Torqt JK in forum Jeep JK Wrangler
    Last Post: 02-03-2015, 04:41 AM
  3. Need some advise
    By Raven Moon in forum General Jeep Stuff
    Last Post: 10-16-2014, 08:48 PM
  4. need some advise
    By Texas Nick in forum Jeep JK Wrangler
    Last Post: 05-14-2014, 07:50 PM
  5. Need a little advise on an air compressor
    By KCTW in forum Jeep JK Wrangler
    Last Post: 12-28-2012, 03:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
