Results 1 to 8 of 8
Thread: Tj
  1. #1
    Fresh Catch
    Join Date
    Jul 2017
    Location
    Madison,WI
    Posts
    7
    Tj
    2006 X tj
    Heater doesn’t work. Changed the resistor and the switch. All the fuses are good. Where to go from here?
  2. #2
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    27,683
    Quote Originally Posted by eatinbiskit View Post
    2006 X tj
    Is the blower blowing? Or it's only blowing cold air instead of hot?
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  3. #3
    Fresh Catch
    Join Date
    Jul 2017
    Location
    Madison,WI
    Posts
    7
    Quote Originally Posted by WJCO View Post
    Not blowing at all. It never made any sound like it might be about to lock up or going bad.
  4. #4
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    27,683
    Put direct power and ground to the blower motor. If it works, then the motor is fine and you've got a circuit issue. If it doesn't work, then it's a bad motor. Also make sure it isn't seized from leaves or dead mice, etc.
  5. #5
    Fresh Catch
    Join Date
    Jul 2017
    Location
    Madison,WI
    Posts
    7
    Thanks. Just hooked it to power and motor is good. Cleaned minimal debris.
    Is there a relay or something I need to look for. I just printed off a schematic and it shows a fuse or something close to hvac right of center.
  6. #6
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    27,683
    Hard to say but there very well could be something there. The first thing I would do is check that the ground wire is good. Then check the power wire and work backwards to see where power is lost (if that's the wire that's open).
  7. #7
    Fresh Catch
    Join Date
    Jul 2017
    Location
    Madison,WI
    Posts
    7
    Okdoke.
  8. #8
    Join Date
    Mar 2014
    Location
    Ga
    Posts
    121
    Don't forget to check the thermostat also. It might need changing.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
