Results 1 to 9 of 9
Thread: 2012 JKU Sport - Drive Shaft Vibration, Need Advice
  1. #1
    Fresh Catch
    Join Date
    Oct 2016
    Location
    San Diego
    Posts
    13
    Hey guys.. A while back my front driveshaft's CV joint exploded. During the commotion, the drive shaft picked up about a 1" long dent in it (Maybe 1/4" deep at most). Unfortunately, I didn't notice the dent until I had already purchased the CV repair kit so I decided to just go ahead and install it and see if it would be ok. Right away it started vibrating whenever the Jeep reaches about 72MPH and maybe it's me being paranoid, but lately I feel like the vibration is beginning sooner, maybe around 62-65 MPH. Anyway, I never expected to drive on it this long but with a slew of unexpected expenses, I just haven't had the money for a new drive shaft so I've just been driving like a grandma and avoiding driving at speeds that trigger the vibration.
    I am wondering if this is something that a drive line shop could rebalance or whether I would just be better off buying a new driveshaft as originally planned? Since money is tight right now, would I be better off just pulling the driveshaft entirely out for the time being until I can properly address the problem? Any ill effects from driving semi-long term (1-3 months) with nothing connected to the T-case?
    Also, if anyone has a recommendation on a replacement front drive shaft that won't break the bank that would be much appreciated. I have heard good things about Tom Woods 1310 and planned on buying that when I have the funds.. but open to suggestions.
    This is for a 2012 3.6l JKU Sport with 3.5" lift, 4.88 gears and 35's.
    Thanks in advance.
  2. #2
    Knows a Thing or Two Seahawkfan's Avatar
    Join Date
    Oct 2016
    Location
    San Jacinto CA
    Posts
    644
    Quote Originally Posted by Meety Peety View Post
    Thanks in advance.
    I have front take-off you can have. It's off a 2011 JKU 3.8 so not sure if it will work. And I won't be home until mid February.
  3. #3
    Addict BaddestCross's Avatar
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,417
    Did you take the whole shaft apart for any reason? If so, did you make sure to reindex it when you put it back together?
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  4. #4
    Fresh Catch
    Join Date
    Oct 2016
    Location
    San Diego
    Posts
    13
    Quote Originally Posted by Seahawkfan View Post
    Hey thanks a lot for the offer, I may have to take you up on that if I can't get this sorted out by then! Much appreciated.
    Quote Originally Posted by BaddestCross View Post
    That is a very good question.. I had a buddy who is a mechanic help me with this since I don't really know what I'm doing. We did separate the drive shaft to make it easier to handle while rebuilding the CV but I do not remember taking any specific care to make sure it went back together at the exact spot.. then again he may have put a little indexing mark or something on it without me even catching it..? I don't suppose there would be much way for me to climb under it and check it after the fact unless I get lucky and find an indexing mark that happens to be lined up? I'll ask him if he remembers.
  5. #5
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,417
    There is a mark on both pieces that should be aiming at each other. I don't recall what the factory uses for the mark, but it should be obvious.
  6. #6
    Fresh Catch
    Join Date
    Oct 2016
    Location
    San Diego
    Posts
    13
    Thanks, I will climb under there and take a look as soon as I am off work.
  7. #7
    Fresh Catch
    Join Date
    Oct 2016
    Location
    San Diego
    Posts
    13
    Just an update, I climbed under the Jeep and could not find any markings. Pushed it in neutral a little ways to spin the drive shaft over, but might have missed it. I think I am going to just pull it out tomorrow so I can take a look at it closer.
    Any input on driving without the drive shaft in? Googling around it looks like it should be no problem.. but wanted to make sure. Most of the references I've seen are short term or related to TJs
  8. #8
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    30,978
    No issues. Just drive it.
    2012 Dozer JK
    -Dynatrac PR44/Rubicon Rear
    -Nitto 37” Trail Grapplers
    -Rock Krawler 2.5” Lift
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    2012 Billet Silver JKUR
    -EVO DTD front and rear
    -Dynatrac PR60/PR80
    -EVO High Clearance Long Arm
    -Nitto 40” Trail grapplers
    -KMC Machetes
    -JE Reel 1410/1350 Driveshafts
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  9. #9
    Join Date
    Oct 2016
    Location
    San Jacinto CA
    Posts
    644
    No problem, Like I said Mid-Feb just send me a PM if you still need it. And look into if it will work or not. 2011 JKU 3.8 Auto
Similar Threads
  1. 2012 Unlimited Sport - Vibration Or Grinding Noise At 9/10 MPH
    By Meety Peety in forum Jeep JK Wrangler
    Last Post: 05-22-2017, 03:37 AM
  2. Vibration - Drive shaft?
    By ERAUGrad04 in forum Jeep JK Wrangler
    Last Post: 11-08-2014, 01:13 AM
  3. Rear drive shaft advice
    By Sugarbear in forum Jeep JK Wrangler
    Last Post: 02-28-2014, 01:47 AM
  4. Front Drive Shaft Advice Needed
    By HiTekRedneck in forum Jeep JK Wrangler
    Last Post: 12-31-2013, 05:43 AM
  5. Drive shaft Vibration
    By Scott226 in forum Jeep JK Wrangler
    Last Post: 07-21-2013, 08:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
