Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Jeep TJ 4wd Question
  1. #1
    Caught the Bug Jranso04's Avatar
    Join Date
    Jun 2016
    Location
    Pennsylvania
    Posts
    57
    My 4wd in my 2005 Jeep TJ continues to kick out and is extremely hard to get into and out of 4 wheel. I had bought the Novak conversion transfer cable but my mechanic said he has done them and it is extremely hard to get them lined up perfectly and if it isnít adjusted perfectly then there is a risk of ruining the gears. What else could I do to fix this problem?
  2. #2
    Nothing but a Thing Snboarder113's Avatar
    Join Date
    Oct 2015
    Location
    michigan
    Posts
    1,368
    I think you need a new mechanic... itís not that hard, tons of people run them. There are other linkage adapters you can choose from if youíre set against it.
  3. #3
    Join Date
    Jun 2016
    Location
    Pennsylvania
    Posts
    57
    I donít have any experience with the kit so I wasnít sure what to do but the mechanic I go to said it would be better to take it to a Jeep dealer and have them replace it with an original part.
  4. #4
    Join Date
    Mar 2014
    Location
    Ga
    Posts
    121
    Some guys did the installation by themselves and the process went smoothly. Try to find another mechanic or ask a friend who has experience installing it.
  5. #5
    Join Date
    Oct 2015
    Location
    michigan
    Posts
    1,368
    Quote Originally Posted by Jranso04 View Post
    Ok letís back up so Iím not making assumptions.
    Itís popping out of 4wd due to the linkage correct?
    You have a Lift kit or transfercase drop? Or did this just recently start happening with no new modification
  6. #6
    Addict JKbrick's Avatar
    Join Date
    Feb 2013
    Location
    Leo, Indiana
    Posts
    7,256
    I wouldnít think Novak would still sell it if itís so hard to put on that people ruin their gears. Grab a few tools and dive in, make yourself proud
  7. #7
    Join Date
    Jun 2016
    Location
    Pennsylvania
    Posts
    57
    Quote Originally Posted by Snboarder113 View Post
    I will put it into 4 lo or even 4 high itís extremely hard to get the lever to fall into the correct place and when I finally get it to go Iíll drive a little and it will grind the gears and kick it out of 4wd. It started happening at the end of last winter. I have no major modifications. Just slightly bigger than stock tires (up to 31ís) and new rims with more backspacing. No lift or anything else. Iíd love to work on it myself but 1 it is my only car and I canít afford to mess something up. And 2 it was my uncles who passed away and Iím trying to make it last for a very long time. Iím a novice when it comes to working on vehicles. Any help is greatly appreciated.
  8. #8
    Join Date
    Feb 2013
    Location
    Leo, Indiana
    Posts
    7,256
    I canít take a pic to show you but the shifter has a rod that pivots between the body and drivetrain, it has a bushing that may have fallen out or somehow the rod popped out of alignment. I would have thought your mechanic would have seen that tho. Too bad you werenít closer Iíd look at it with you. Put out a feeler and see if anyone is close to you that could help
  9. #9
    Join Date
    Jun 2016
    Location
    Pennsylvania
    Posts
    57
    Quote Originally Posted by JKbrick View Post
    Thank you for the help. My mechanic didnít really look at it. He was swamped with end of the month inspections he was just telling me what he thought about the new cable. He did say that though to get new bushings and grease the crap out of it. Thank you for the help though. Iíll have to do more research on it. Thank you again though I really appreciate it!
  10. #10
    Join Date
    Oct 2015
    Location
    michigan
    Posts
    1,368
    New bushings on the linkage and readjustment should be all you need. Or install the novak, its a good unit and it just needs to be adjusted, no different then adjusting the oe one.
Similar Threads
  1. Buying a used Jeep Question
    By arahambone in forum General Jeep Stuff
    Last Post: 01-05-2018, 10:09 PM
  2. considering a new Jeep and Have a question
    By wanderer in forum Jeep JK Wrangler
    Last Post: 07-02-2017, 06:38 AM
  3. Jeep Purchase Question
    By Whiterave in forum Jeep JK Wrangler
    Last Post: 12-07-2014, 02:16 AM
  4. Jeep jamboree cb question
    By Cpyrd in forum The 8th Slot
    Last Post: 02-06-2014, 02:09 PM
  5. Jeep xj 3'' lift question
    By ripperxj in forum Jeep Cherokee & Grand Cherokee
    Last Post: 08-23-2013, 08:42 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
