Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 58
Thread: Mounting Beadlocks?? Need some help
  1. #41
    Hooked WiscoHR's Avatar
    Join Date
    Dec 2015
    Location
    United States
    Posts
    186
    Quote Originally Posted by Ddays View Post
    From what I've seen, its the Coopers. The E sidewalls are a mother. I watched Mel's video where he basically throws the wheel into the tire and Viola!
    Uh-huh, yeah no. Ain't happening with the Coops. I think I pm'd Eddie 10 times trying to figure out what in the hell I was doing wrong. They are just a bitch. There's a sweet spot angle that once you find it they'll pop on, but not without a fight.
    Itís definitely all about the angle. Got to get one lip just inside the bead but still have the wheel as flat as possible. Otherwise itís a fight youíll never win.
  2. #42
    Join Date
    Oct 2018
    Location
    California
    Posts
    63
    Quote Originally Posted by jesse3638 View Post
    I'm curious if anyone on here has mounted them on any other bead lock and if they've had difficulty.
    I got them on the KMC XD231 wheels like Eddies no problem, wheel on a piece of cardboard, little lube (I used conduit lube for pulling wire), get it started in the drop center, then just jumped onto the tire with my hands and knees... I am a big guy maybe a little extra weight helps.
    Attached Images Attached Images
  3. #43
    Been Around the Block Steve Williams's Avatar
    Join Date
    Jul 2017
    Location
    Tucson, AZ
    Posts
    271
    Quote Originally Posted by CalSgt View Post
    They look great on your Jeep, polished and white is a nice looking combo. I hope you have some video of your install technique. ;-)
  4. #44
    Join Date
    Oct 2018
    Location
    California
    Posts
    63
    Quote Originally Posted by Steve Williams View Post
    I got the technique from watching youtube (below at about 2:00)... It seemed easier than the way Eddie shows in his video because I am a klutz, I'd likely twist an ankle trying to balance standing in the wheel.
    https://www.youtube.com/watch?v=QQcJCLv25jU
    I've mounted thousands of tires but had a machine to do most of them, & most of the ones done by hand were equipment or semi tires where there was no worry of scratching wheels with tire spoons. Because no shop I ever worked at would have allowed us to mount them I had only done one other set of beadlocks, some 30x9.5 r15 BFG KR2's on Walker Evans for my RZR...
  5. #45
    Knows a Thing or Two Jkzinger's Avatar
    Join Date
    Apr 2012
    Location
    Sahuarita, Arizona
    Posts
    933
    I mounted my 40 inch coops on my ATX Slabs and did not have much trouble at all.
  6. #46
    Addict Ddays's Avatar
    Join Date
    Aug 2015
    Location
    Darlington, Pa
    Posts
    8,926
    Quote Originally Posted by Jkzinger View Post
    40's are load range C aren't they? The 37's are E and I believe that's what causes the difficulties.
  7. #47
    Addict BaddestCross's Avatar
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,423
    Are the Cooper 37s E? My Nitto 35s were E but my 37s are D.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  8. #48
    Old Timer dillard09's Avatar
    Join Date
    Dec 2014
    Location
    Redondo Beach
    Posts
    2,831
    Quote Originally Posted by BaddestCross View Post
    I believe...
    37x12.50 are D
    37x13.50 are E
    '08 JKUR 6.0LS, 6L80
    EVO DTD, Evolever w/ Hi Clearance long arms
    40x13.50R17 Nitto TGs w/ KMC Machettes
    Dana 60, Sterling 10.5
    EVO stuff
    Evo Pro & Warn Zeon
    Evo Tire Carrier
  9. #49
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,423
    Quote Originally Posted by dillard09 View Post
    I believe...
    37x12.50 are D
    37x13.50 are E
    Ahh... Makes sense. I run 12.5 👍
  10. #50
    Join Date
    Aug 2015
    Location
    Darlington, Pa
    Posts
    8,926
    I believe...
    37x12.50 are D
    37x13.50 are E
    Ahh... Makes sense. I run 12.5 ��
    Yup, I shoulda noted that ^^.
    I went with the 13.50's not only because they were wider, but they were also significantly cheaper.
Similar Threads
  1. Re-selling tire advice (beadlocks to non-beadlocks)
    By boardsurfer in forum Wheels & Tires
    Last Post: 03-04-2018, 06:17 AM
  2. Mounting beadlocks, almost done but need help
    Last Post: 09-06-2016, 02:39 AM
  3. Trade 18" beadlocks for 17" beadlocks
    By OhNoTheJiggies in forum Wanted (Active Members ONLY)
    Last Post: 02-24-2015, 03:01 AM
  4. Trouble mounting slab beadlocks
    By Tmac in forum Wheels & Tires
    Last Post: 02-13-2014, 08:41 PM
  5. Mounting gas can
    By 13JKUR in forum Jeep JK Wrangler
    Last Post: 08-08-2013, 10:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
