Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 97
Thread: Disaster averted
  1. #81
    Old Timer BaddestCross's Avatar
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    4,764
    Quote Originally Posted by jdofmemi View Post
    Maybe this helped it along
    I believe he said "I felt like more gas would help" or something to that effect. 😂
    Yeah, that might've been the last straw. 😎
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  2. #82
    Old Timer fiend's Avatar
    Join Date
    May 2017
    Location
    SoCal
    Posts
    2,700
    Quote Originally Posted by BaddestCross View Post
    When in doubt, throttle out! 🤣
  3. #83
    Join Date
    May 2017
    Location
    SoCal
    Posts
    2,700
    Quote Originally Posted by A.J. View Post
    Little late here but I have a pair of factory knuckles if you need them. A lot closer than Hawaii.
    Brute helped me out, but thanks all the same!
  4. #84
    Join Date
    May 2017
    Location
    SoCal
    Posts
    2,700
    Quote Originally Posted by wjtstudios View Post
    Santa Brute to the Rescue!
    I have to believe the Reid’s are significant stronger. Here’s a picture I found comparing them.
    Attachment 316353
    How much you’d have to discuss with them. But in the picture, you can see how much that tie rod gets raised.
    Thanks. There is some verbiage on Reid’s site about extra material and extra strength, but the “off road use only” admonition and the disclaimer of any warranty don’t exactly inspire confidence.
    Quote Originally Posted by jeeeep View Post
    I was getting that same small amount of rubbing on the tie rod as well and it just didn't seem worth moving the tabs for that small amount.
    The spacer has worked out great.
    Just get a slightly longer bolt and I went from the bottom up.
    Thanks. Effective solution.
    I’m still undecided. Probably will just install Brute’s OEM knuckles, save $400-500, and call it a day.
  5. #85
    Join Date
    May 2017
    Location
    SoCal
    Posts
    2,700
    Ed (Brute) graciously sent me a set of OEM knuckles. I installed the driver side knuckle and that’s served me well for a couple of months. Im the meantime, I picked up some Rancho knuckles. To install those, I need to cut my PSC ram tabs off the TB bracket and move them up 1.5 inches. Got the new tabs today from Summit. Question is, while I have it all apart, should I install the dynatrac ball joints that have been sitting in my garage for a while, or get some more life out of the synergy’s I have in now?
  6. #86
    Old Timer HighwayTrout's Avatar
    Join Date
    Dec 2013
    Location
    California
    Posts
    3,042
    Gnarly. Glad you found it before it found you!
    en hopup veritas
  7. #87
    Nothing but a Thing Clutch's Avatar
    Join Date
    Dec 2015
    Location
    STL metro
    Posts
    2,371
    Quote Originally Posted by fiend View Post
    Prosteers !
  8. #88
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    4,764
    Wait for the death wobble. You appear to enjoy living on the edge. 😂
  9. #89
    Old Timer TrailHunter's Avatar
    Join Date
    Apr 2016
    Location
    SoCal
    Posts
    3,474
    I vote start fresh with the Prosteers... eliminates any question of fault in the new build.
  10. #90
    Join Date
    May 2017
    Location
    SoCal
    Posts
    2,700
    Quote Originally Posted by HighwayTrout View Post
    Yes for sure. Between that and the cracked knuckle discovery, I think I’ve maxed out my luck for a while.
    Quote Originally Posted by Clutch View Post
    Prosteers !
    Yeah, doesn’t make a lot of sense to have them sitting in the garage. On the other hand, I’d like to amortize the synergys.
    Oh man, I’ve had the death wobble fun in the past. It really sucks.
    Quote Originally Posted by TrailHunter View Post
    Yeah there’s something to that logic. No matter what, between the knuckles and the transfer case, I have projects to keep me busy for a while.
Similar Threads
  1. Pony express disaster.
    By RESURECTIONJK in forum Destinations & Beyond
    Last Post: 11-13-2017, 08:16 PM
  2. The night disaster struck
    By Irish JK in forum Jeepin Life
    Last Post: 02-21-2017, 07:00 PM
  3. DEAD JEEP - 2014 JK - Superchips Flashpaq Disaster
    By D1EHARD in forum Jeep JK Wrangler
    Last Post: 04-10-2014, 01:58 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
