Results 1 to 9 of 9
Thread: Beadlock thread stripped
  1. #1
    Been Around the Block Guascone's Avatar
    Join Date
    Feb 2015
    Location
    Italy
    Posts
    481
    Today the tires shop changed my tires...I came back home (200km) and I checked the bolt torque...I noticed that one of the thread has bene stripped...now what I have to do?
    Is there a way to repair my wheel?
    A metallic insert?
  2. #2
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    25,431
    Quote Originally Posted by Guascone View Post
    A metallic insert?
    Shop needs to do the legwork to find out how to repair it. I would take it back to them and show them what happened.
  3. #3
    Addict Ddays's Avatar
    Join Date
    Aug 2015
    Location
    Darlington, Pa
    Posts
    7,659
    A metallic insert?
    Depending on the brand wheel you have, the inserts are replaceable relatively easy. It's a pain in the ass to be sure, but the process is easy.
    Here's an old thread on the inserts for ATX Wheels: https://wayalife.com/showthread.php/...ame-out!!-Help!
  4. #4
    Join Date
    Feb 2015
    Location
    Italy
    Posts
    481
    You are fully right!
    Iím already in contact with the shop...they will pay for the repair but first of all I would understand if the wheel is repairable...if not I will ask for a new wheel...
  5. #5
    Hooked SLO's Avatar
    Join Date
    Jul 2016
    Location
    Portland, OR
    Posts
    142
    A metallic insert?
    Iím surprised you found a tire shop to work on beadlocks.
  6. #6
    Knows a Thing or Two Jkzinger's Avatar
    Join Date
    Apr 2012
    Location
    Sahuarita, Arizona
    Posts
    846
    Quote Originally Posted by SLO View Post
    I am surprised Italy allows beadlocks.
  7. #7
    Join Date
    Feb 2015
    Location
    Italy
    Posts
    481
    The beadlock wheels are becoming quite common in Italy( there isnít a dedicated law that allow them or not) ...the tire shop is an official Bfgoodrich off road center...his owner is a jeeper and should now very well the job...I was hoping...
  8. #8
    Nothing but a Thing sipafz's Avatar
    Join Date
    Mar 2015
    Location
    Saukville, Wisconsin
    Posts
    2,049
    A metallic insert?
    To answer your question, Iím sure that your wheel can be repaired. Whether that makes sense needs to be determined:
    Cheaper wheels that do not have inserts can be fixed rather easily by adding a threaded insert. Helicoil repair kits are available for around $25 on Amazon and can be installed with low to medium skill level.
    More expensive wheels can be a lot more difficult to repair. They already have threaded inserts and the damage is usually that the insert spun in the wheel so itís not as simple as just replacing the insert. In some cases a plug style insert can be used like from Jergens, but these inserts are larger than Helicoils and depending on the wheel it may not fit or have enough supporting metal around the plug. If that is the case then the wheel needs to be welded which starts getting a little sketch as the welding may distort the wheel and is more labor to prep and re-machine the hole. This is when it might be better to just get a new wheel.
    Either way, good luck and I hope your repair works out!
  9. #9
    Join Date
    Feb 2015
    Location
    Italy
    Posts
    481
    Quote Originally Posted by sipafz View Post
    Thanks a lot for your very clear explanation!!!
Similar Threads
  1. need help removing stripped lug nut
    By 2014siljk in forum Jeep JK Wrangler
    Last Post: 03-05-2017, 08:12 PM
  2. Stock Jk Tie Rod Stud Stripped?
    By SkylerMitchell in forum Jeep JK Wrangler
    Last Post: 02-22-2017, 01:54 AM
  3. PIGINAJK8 Stripped Down!!
    By piginajeep in forum Jeep Show & Tell
    Last Post: 09-10-2015, 09:45 AM
  4. Help! I've got a lot of stripped insulation on wiring.
    By deerhound in forum Jeep JK Wrangler
    Last Post: 06-18-2015, 07:23 PM
  5. Oil pan bolt stripped
    By mstrofpuppets in forum Jeep JK Wrangler
    Last Post: 12-01-2014, 02:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
