EVO Enforcer to Enforcer Pro conversion question
MericaMade
I am thinking about converting from the Evo Enforcer Stage 3 Draglink flip to the Enforcer Pro with coilovers and I want to make sure I understand this the process correctly. I can get my hands on an almost new set of coilovers but want to make sure of the other parts I will need.
Coming from the Stage 3 Enforcer with draglink flip, rear track bar relocation, extended break lines, and front shock relocates, I want to make sure the following are the only parts I will need. The coilover tower buckets, rear rock star shock mounts, rear sway bar spacer and hardware?
kingsize
Don't forget to swap out the rear trackbar bracket as well. The Enforcer trackbar bracket has a jog in it that could/will destroy the coilover piggyback res. The Enforcer Pro trackbar bracket is flat and will eliminate contact.
Robert @ EVO MFG
MericaMade
Robert @ EVO MFG
Thank you for letting me know about that, I would have just assumed they were the same parts.
MericaMade
Robert @ EVO MFG
Is these part numbers EVO-12028 for Enforcer Pro Coilover and EVO-1072B for Enforcer with King shocks?
MericaMade
Is anyone running the enforcer with the 2.5 3-5 inch King rear resi with 3inch coils and the Evo rear Rockstar skids? The measurements look too close for clearance but I was hoping someone who's running it or EVO can respond.
Sharkey
Word Ninja
I’m pretty sure that is what MTG had on his white Jeep. You could pm him or look through his Knuckles build thread to confirm.
Exodus 4x4
I’ve installed this for customers, WITH limiting straps. If you don’t the 3” springs will come unseated
MericaMade
Yeah I've seen in another post where you states that at that as well. For me I know I put this kit to its absolute flexing maxpoint and never had any issues like that. I am however running a little bit shorter rear sway bar connector which could be limiting my droop out. The ones that Evo sends in the kit were just extremely too long.
Exodus 4x4
3” plush rides with Kings and rockstars. On the lift in the shop, the springs fell out. Really short sway bar links could prevent that I guess.
DWiggles
Also are you using a 3 or 4 inch rear bump stop with rockstar slider?
When I was still running springs, my shock compression was something like 16.5" (IIRC) *not King shocks*
I had to switch to the 4" bump stops as my shocks were bottoming out before the full factory bump.
It's in my build thread... check the 2nd post for links
sent from SPACE!
DZZ Build thread
MericaMade
When I was still running springs, my shock compression was something like 16.75" (IIRC) *not King shocks*
sent from SPACE!
DZZ Build thread
Thanks I will take a look.
DWiggles
Thanks for posting all that, its great info and wish I found that earlier searching.
Side note on this, FlatTop was running (I believe) RK 3.5 springs (IIRC) with the bilstein & rockstar setup and was unseating the rear coils (literally falling off the jeep) at full flex... We ended up loosly zip tieing the springs to the upper & lower coil perchs the second time it happened since it was nearly freezing outside despite expecting weather to be well into the 50°s... things were just fine for the rest of the trail. He has since switch to bolt-on coilovers.
Moral of the story: definitely cycle the suspension before heading out. :thumb:
