Results 1 to 7 of 7
Thread: Floaty Steering!!
  1. #1
    Fresh Catch SkylerMitchell's Avatar
    Feb 2017
    Tri Cities, Washington
    43
    Floaty Steering!!
    Havenít posted in a while but I am in need of some help/advice. My 2 door jk has pretty loose steering that needs badly addressed. I have replaced the track bar, drag link, tie rod, and ball joints with all new aftermarket parts. Iíve also tightened the hex head nut on top of the steering box a bit, but not too much. I donít want to over tighten. Not sure where else to look. Maybe in the column itself? Any help appreciated.
  2. #2
    Old Timer BaddestCross's Avatar
    Aug 2016
    Palmdale, CA
    4,378
    Quote Originally Posted by SkylerMitchell View Post
    Have you lifted it? If so, how much and did you fix the caster? Are your track bar and drag link parallel? What type and size tires and what pressure are you running?
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  3. #3
    Caught the Bug Whitarmy's Avatar
    Aug 2017
    Texas
    70
    I had to get adjustable front control arms to fix mine
  4. #4
    Dec 2012
    Franklin, TN
    69
    It sounds like you need to check your alignment to start. Mine was a little floaty, even with lower adjustable control arms in the front, I literally just put upper adjustable control arms on and it is all but gone now. Check the basic do it at home alignment thread for how to get started. Click HERE:
    2017 White JK : (build thread)
    Synergy 3"/2", Dynatrack Trail Leader Package
    MCE Fenders, 10th Anniversary Hood
    ATX Slabs, Nitto Trail Grappler 37's
    Shrock Works Front Middy, LoD Destroyer Rear
    Genright Sliders, Warn VR12-S ,
    Oh yeah, and VENGEANCE.
  5. #5
    Old Timer wjtstudios's Avatar
    Nov 2016
    Rochester, MI.
    3,206
    Another point to check will be the input shaft on the steering gear to see if the main steering gear is shot. Reach up and grab hold of the input shaft going into the gear and see if you can turn it. A little play is normal, if you can get a quarter turn or more out of it and youíve already tightened the hex nut, the steering gear is probably shot. If thatís still tight, then itís further down the line.
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
  6. #6
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    25,431
    Other members have addressed the best places to start. Also if for some reason you have an aftermarket pitman arm, make sure it's fastened properly and there is no play in the splines where it meets the gear box.
  7. #7
    Addict jeeeep's Avatar
    Oct 2011
    Tx
    5,339
    ask here 1st before replacing parts...save you some money
    all good troubleshooting starting points.. IMO begin with caster, doesn't take much to makes a difference
Similar Threads
  1. Steering
    By 97JSadowski in forum Jeep TJ & YJ Wrangler
    Last Post: 09-19-2017, 07:24 PM
  2. Floaty steering
    By tallguy26 in forum Jeep JK Wrangler
    Last Post: 05-08-2017, 12:25 PM
  3. XJ Steering
    By tANNERRRR in forum Jeep Cherokee & Grand Cherokee
    Last Post: 09-20-2016, 02:42 AM
  4. Steering stabilizer with PR44 and Synergy Steering
    By troy-bilt in forum Jeep JK Wrangler
    Last Post: 02-01-2016, 09:31 PM
  5. Steering Slippage/Bump Steering Problems
    By NAUXJ in forum Jeep JK Wrangler
    Last Post: 10-12-2015, 11:56 PM
