Results 1 to 8 of 8
Thread: Crush sleeve eliminator vs crush sleeve?
  1. #1
    Old Timer USMC Wrangler's Avatar
    Feb 2015
    Cochise County, AZ
    3,304
    Iím finally getting around to my gear swap. The rear is getting a master rebuild kit and new R&P but my front is the D30 from MybadJK with fairly new 4.56 gears. Because my housing is in better shape, with c-gussets, LCA skids and everything else complete, the gears from the donor axle will go in my OE axle.
    My buddy doing the swap for me will setup the front gears just to be sure. He told me to get a pinion seal, crush sleeve and pinion shims. The first thing that popped up in my internet search is a crush sleeve eliminator by Yukon.
    He says heís never used them but also never heard anything good or bad about them. I already have a pinion seal on hand, so it kinda looks like this kit would do the trick. But! If thereís some reason to not run this on a DD Jeep and you guys know, Iíd appreciate hearing about it.
    2013 JKU Sport "Spider" with some EVO goodies and a chop here and there
    Overall "build thread" http://wayalife.com/showthread.php?2...ker-quot-build
  2. #2
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    26,035
    It's just a different way to set the preload. If your guy is used to crush sleeves, might as well just stick to that. One benefit to the eliminator is if you ever have to remove the pinion nut, you can just tighten it down without worrying about over-tightening the bearings.
    And the pinion shims he asked you to get are not the ones that come with the eliminator. The ones you want to down near the gear head. You want pinion depth shims.
  3. #3
    Nothing but a Thing QuicksilverJK's Avatar
    Apr 2016
    Reno NV
    1,368
    The eliminator is good for future repairs such as replacing the pinion seal. Also if there is a mistake made on initial setup then you just adjust shims as apposed to having to buy another crush sleeve.
  4. #4
    Feb 2015
    Cochise County, AZ
    3,304
    Ahh, ok. So something like this is probably my best bet?
    https://www.revolutiongear.com/produ...evolution_gear
  5. #5
    Sep 2015
    Colorado
    26,035
    Quote Originally Posted by USMC Wrangler View Post
    That's what I would do. As a matter of fact, I think that's the exact same kit I got from Exodus when I did ours.
    Hopefully Exodus or Dynatrac comments on this in regards to whether there is a major benefit to the eliminator. I'm pretty sure Dynatrac uses them on their ProRock 44.
  6. #6
    Advertiser Exodus Jeeps's Avatar
    Feb 2015
    Texas
    2,519
    Itís whatever people are comfortable with. Personally I like the eliminator kit but the crush sleeve is faster.
  7. #7
    Addict JKbrick's Avatar
    Feb 2013
    Leo, Indiana
    6,503
    I donít know how to do gearing YET but my plan would be to use the eliminator in case I would have to change my yoke that it would make it easier to put back together
  8. #8
    Feb 2015
    Cochise County, AZ
    3,304
    Thanks Doug!
    Quote Originally Posted by Exodus Jeeps View Post
    Gotcha. Makes sense, thanks!
    Quote Originally Posted by JKbrick View Post
    This makes sense too. Iíll check with my buddy and see if he wants to give it a try on the front internals swap or not. This is a complete learning process for me too.
    Thanks fellas!
Similar Threads
  1. Tie rod adjustment sleeve seized
    By 10abadilla/jk in forum Jeep JK Wrangler
    Last Post: 04-04-2017, 09:22 PM
  2. EVO Magnum Sleeve Seals
    By hhunter050 in forum Jeep JK Wrangler
    Last Post: 01-30-2017, 12:50 AM
  3. New crush sleeve and reshiming for rear driveshaft swap?
    By jorgelrod in forum Jeep JK Wrangler
    Last Post: 12-27-2016, 10:56 PM
  4. Sleeve or Chromoly shafts?
    By aaronstephen in forum Jeep JK Wrangler
    Last Post: 05-20-2013, 07:26 PM
  5. To sleeve... Or not to sleeve...
    By RockIt Man in forum Jeep JK Wrangler
    Last Post: 11-07-2012, 01:56 AM
