Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Overland TJ Build ideas
  1. #1
    Caught the Bug dustinfromohio's Avatar
    Jan 2019
    Ohio
    73
    So I realize there are a dozen vehicles better suited for long distance travels than a TJ but I love the platform so I want to attempt it anyways. My goal is to build a vehicle capable of traveling across the country somewhat comfortably, hitting all the national/state parks along the way, then exploring places like Moab when we get there. I donít plan on doing any serious wheeling, mostly just mild stuff while Iím out exploring for a week or two at a time. Most of these trips will be with any combination of my gf, daughter, and a dog (or 3). Below is how the Jeep currently sits along with some questions Iím rolling around. I apologize for the long windedness and thanks in advance.
    Current setup:
    2002 Jeep TJ
    4.0
    NV3550
    Open Dana 30/35 with 3.73s
    Zone 3Ē lift, nitro shocks, adj track bar
    Psc stinger front bumper
    Unknown brand upgraded rear tire carrier
    265/70R17 Toyo AT2s
    Unknown brand frame mounted rocker guards
    Best way to increase cargo capacity- trailer, overhead rack, hitch mounted cargo carrier (all have their drawbacks)
    Optimal tire size- possibly upgrade to 33x12.50, 33x10.50, or 34x10.50? (I donít know out west enough to know what I really need, 3.73s are ok but id prefer a little lower gearing even with current setup so regearing will probably happen regardless)
    Upgrade axles for more durability- chromoly shafts in 30, swap in a non rubicon 44?
    Travel question- do you guys usually tent it, air bnb, hotels? Camping would be fun but seems to add a ton of extra supplies.
  2. #2
    Addict wjtstudios's Avatar
    Nov 2016
    Rochester, MI.
    6,114
    If you planning on doing a ton of miles, Iíd start by focusing on ride. Shocks and Springs. Iíd look at the rancho 9000 adjustable shocks so you can dial it in based off the load your carrying.
    I wouldnít run a lot of load up high, keep the COG as low as you can. A hitch rack and waterproof bags are great. If you need more room, you might look at a small trailer. You can search the forum, Thereís a lot of guys that have built them.
    Good luck.
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
  3. #3
    Been Around the Block 98XJ06LJ's Avatar
    Jul 2017
    US
    381
    For the type of wheeling that you are talking about you are fine on stock diffs with a 33" tire. Maybe upgrade the axles shafts while regearing to 4:10, not sure I would go more than that as you are also going to be on the highway the majority of the time.
    I think a trailer is going to be your best bet as you have stated you will have three people in the rig. Just keep it low profile. The wind drag kills you on the highway. This allows you to disconnect at the trail head or camp site and leave all that excess weight behind when wheeling.
    Sent from my Moto Z (2) using WAYALIFE mobile app
  4. #4
    Jan 2019
    Ohio
    73
    Quote Originally Posted by 98XJ06LJ View Post
    I like the small trailer idea as the Jeep already has a hitch and the wiring and it would give me more options for taking my kayak places this summer. Plus I could get pretty creative on design/features. If I stay with 4.10s it may be cheaper to find a set of factory axles already geared that way and swap them.
  5. #5
    Jul 2017
    US
    381
    Quote Originally Posted by dustinfromohio View Post
    Especially if you have a pick a part or any other option for a pull it yourself junk yard. You can pick up complete assemblies for a couple hundred bucks.
  6. #6
    Jan 2019
    Ohio
    73
    You think 4.56s would be out of the question even with pulling the trailer?
  7. #7
    Nov 2016
    Rochester, MI.
    6,114
    That might be too steep for all the road miles you are doing. 4:10s and 33s is the way to go.
  8. #8
    Jul 2017
    US
    381
    Quote Originally Posted by wjtstudios View Post
    Agreed. 👆
  9. #9
    Fresh Catch
    Mar 2019
    US
    4
    Delete....
  10. #10
    Been Around the Block sm31's Avatar
    Nov 2012
    Eagle River, AK
    294
    Another vote for the trailer. I'm also a fan of keeping the load down low... plus the drawback of rooftop setups is you have to pack it all up every time you move the vehicle. A trailer OTOH can serve as a nice home base while you make excursions around the area... while keeping your rig light (as someone already pointed out). A final plus on the trailer is that you will have far more carrying capacity than anything on or in the vehicle could match.
    If it were a JKU, there might be some trailer-less options but I couldn't see doing it any other way in my 2001 TJ.
Similar Threads
  1. Willys-Overland Build Thread
    By Saharaunlmtd in forum Member Jeep Builds
    Last Post: 12-03-2018, 03:48 AM
  2. 2 Door JK Overland Build with Trailer
    By WR_Outlander in forum Member Jeep Builds
    Last Post: 07-10-2017, 09:12 PM
  3. Mike's 02 Overland Build (Pepper)
    By 97mule in forum Jeep Cherokee & Grand Cherokee
    Last Post: 03-28-2017, 01:39 AM
  4. Oversized Overland Build
    By TrailRidden in forum Member Jeep Builds
    Last Post: 04-24-2016, 03:40 PM
  5. Overland/Expedition build.
    By Bryantengland14 in forum General Off-Road Tech
    Last Post: 09-18-2015, 05:59 PM
