Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
Thread: Death wobble help
  1. #11
    Addict wjtstudios's Avatar
    Join Date
    Nov 2016
    Location
    Rochester, MI.
    Posts
    5,703
    You can move your pitman arm up? Not the drag link? If you can move the Pitman at all, the piece that comes off the steering gear, that is a significant problem. That should be rock solid and torqued to I think 150 lbs stock, the big bores require 225 lbs.
    I agree with Eddie, the bent wheel, can create a harmonic vibration that can then escalate into a full DW given the proper weaknesses in other areas. Have the wheels properly checked and balanced to rule that out.
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
  2. #12
    Hooked Jeeper125's Avatar
    Join Date
    Jun 2016
    Location
    Northern New Jersey
    Posts
    129
    The pitman arm seems tight on the sector shaft I think the up and down play might b coming from the box, will definitely go a get my tires balanced
  3. #13
    Join Date
    Nov 2016
    Location
    Rochester, MI.
    Posts
    5,703
    Quote Originally Posted by Jeeper125 View Post
    There might be an issue with the gear. Everyone Iíve had has been rock solid.
  4. #14
    Not That Kind of Engineer olram30's Avatar
    Join Date
    Oct 2013
    Location
    wyoming
    Posts
    7,229
    Have you rotated your tires?
  5. #15
    Join Date
    Jun 2016
    Location
    Northern New Jersey
    Posts
    129
    I have not rotated my tires that is something I still have to do, hopefully it will make a difference......
  6. #16
    Fresh Catch YDAJC's Avatar
    Join Date
    Dec 2018
    Location
    VA
    Posts
    25
    Chased this same probelm on my 2017 JKURR, turned out to be an out of round tire. Evertime I hit a bump the front end would shake and over 50 it would develop a DW.
    Installed Dyna trac Ball joints ( Lower OEM units were shot at 4300 miles with 35s)
    New tie rod from Metal cloak (1 T ends)
    New drag link from Metal Cloak (1T ends)
    Track bar from MC
    Reid racing knuckles (OEM were bent assuming from the factory)
    Retorqued the link arms MC game changer 4.5
    re-adjusted toe to 1/8th
    caster set to -5.5
    All helped but the DW would still show up. Left front BFG KO2 (8000 miles on it) was out of round by 1/2 inch. R&Rd the left front and all is happy again.
  7. #17
    Join Date
    Dec 2016
    Location
    Detroit
    Posts
    53
    I had steel wheels on my Jeep and could never get death wobble to go away contact one of your local Jeep clubs and see if someone will let you borrow their wheels and tires to drive around the block
  8. #18
    Join Date
    Jun 2016
    Location
    Northern New Jersey
    Posts
    129
    I still have my stock rims and tires that I could throw on but would the Jeep b less likely to wobble with smaller tires?
  9. #19
    Addict jeeeep's Avatar
    Join Date
    Oct 2011
    Location
    Tx
    Posts
    5,528
    no, just be sure to change your tune back to stock tire size if needed.
  10. #20
    Join Date
    Jun 2016
    Location
    Northern New Jersey
    Posts
    129
    Little update: tried to put in stock tires and rims today and stock rim was making contact with my drag link flip end so had to put my 37s back on, I know itís a band aid but put on a new steering stabilizer cause my old one blew its seal and all the fluid leaked out. After driving it with the new stabilizer there was no dw but there was still a small shimmy at around 40-50. I think I may just start saving up for new rims and see if that eliminates my dw. Cant really think of anything else that could really b cause my Jeep to have full on dw.
Similar Threads
  1. Death wobble
    By JONORTIZ26 in forum Jeep JK Wrangler
    Last Post: 10-09-2017, 10:13 PM
  2. Death wobble
    By BrinksLJ in forum Jeep TJ & YJ Wrangler
    Last Post: 06-03-2017, 03:07 PM
  3. Another cause of Death wobble
    By MattAlpha in forum Jeep JK Wrangler
    Last Post: 03-11-2015, 04:53 AM
  4. Death wobble
    By BlackHawk08jk in forum The 8th Slot
    Last Post: 03-06-2015, 08:21 PM
  5. Death Wobble
    By CaliCrusher in forum Jeep JK Wrangler
    Last Post: 11-10-2013, 03:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
