Page 7 of 7 FirstFirst ... 567
Results 61 to 67 of 67
Thread: VIDEO : JL JOURNAL - How to Install 1350 Drive Shafts on a JL WRANGLER
  1. #61
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    51,320
    Quote Originally Posted by x7tristan View Post
    Thanks for a great video! Had one question, for the rear pinion nut torque, you read 41inlb, will that be the same for all JLURs? I.E. do I still have to figure out what my factory torque setting is?
    The preload will be different for every Jeep. As I state in the video, checking this isn't exactly required but it is a step that I do. I'm pretty sure that Adam's doesn't even include it as a step in their instructions.
  2. #62
    Been Around the Block
    Join Date
    Jan 2013
    Location
    Ontario Canada
    Posts
    496
    Awesome videos, thank you! I've binge watched all your most recent videos, always learn from them.
    This video was the first to help me understand the pinion angle adjustment out back.
    With the quality of your productions, and the content, I'm amazed you guys don't have a weekly show on Discovery Channel or something like that!
    One question with respect to my 2016 JKR, 2.5" lift, stock D44, with GEO brackets (AEV).
    Planning a drive shaft for the front, and understand it's a trade off's for caster, flighty steering and pointing the pinion at the T-Case.
    It is as simple as remove and install new up front? Possible of getting vibes in this case? Am I over thinking this one?
    Thanks again!
    2016 JKR
  3. #63
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    51,320
    Quote Originally Posted by webejeepin View Post
    Thanks again!
    The number one thing that will get you feeling driveline vibes at all is a driveshaft that isn't balanced and so long as you're running factory gears, 4.10's or lower, you may not even notice an unbalanced shaft. However, once you get up into 5.13 or higher, the shaft will spin so fast that any imperfection would be felt. Likewise, the more your shaft is not in line with the pinion, the greater the chance is that those imperfections will be felt even more. As you mentioned, caster needs to take precedence over the pinion lining up with the driveshaft but so long as your shaft is balanced and you're running about factory caster, you shouldn't feel any vibrations. Of course, if you were running something like a ProRock axle with it's built in 6° of caster, it's a lot easier to get your pinion lining up or very close to it.
  4. #64
    Been Around the Block jjlong's Avatar
    Join Date
    Apr 2015
    Location
    SoCal
    Posts
    359
    Thanks for the video! It was very informative. I think I watched it 3 times before I installed my driveshaft and still managed to screw it up! My brain must have been on break when I assumed that loctite that was provided was a lubricant. Now I'm ordering new seals.🤪
  5. #65
    That dude from Mississippi notnalc68's Avatar
    Join Date
    Jan 2015
    Location
    Madison, MS
    Posts
    13,778
    Quote Originally Posted by jjlong View Post
    Well, we learn by doing.
    Build Thread-- http://wayalife.com/showthread.php?3...l-II-The-Deuce
  6. #66
    Join Date
    Jan 2013
    Location
    Ontario Canada
    Posts
    496
    Huh, didn't think about gear ratio making the driveshaft spin faster....good to know. I see I forgot to note I am running the stock 4:10's.
    Appreciate the explanation, sounds like with a good quality drive shaft that is well balanced, I shouldn't feel any vibes, so in theory neither should my transfer case. (I drive about 650 KM per week)
    Cheers
    2016 JKR
  7. #67
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    51,320
    Doh!
    Cheers
    Yup, right now, your front driveshaft will spin about 4 times for every one full rotation of your tires. With 5.13 or higher, it'll be more than 5 times and that's pretty damn fast for a shaft without any load and with a pinion slightly down from it. So yes, you should be good to go so long as your shaft is well balanced.
Similar Threads
  1. Replies: 7
    Last Post: 09-24-2018, 03:36 PM
  2. Replies: 15
    Last Post: 06-09-2018, 09:22 AM
  3. Adams 1350 Rock Crawler Drive Shafts
    By Grappler in forum Jeep JK Wrangler
    Last Post: 10-24-2014, 11:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
