Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Seized control arm advice needed
  1. #11
    Nothing but a Thing Arrcherr's Avatar
    Join Date
    Aug 2017
    Location
    Palos Hills
    Posts
    2,126
    Quote Originally Posted by Speedy_RCW View Post
    Try some wax. Iíve used it successfully many times at work when penetrating oils wouldnít do the trick. Heat up the part, in your case the adjuster, and melt wax down into the threads. Keep in mind the wax will flow toward the heat source so position the torch accordingly. You donít want it to get so hot it burns the wax out. Just enough to melt it and suck it back into the threads. Iíd try this method before you put a ton of leverage and end up breaking something.
    That's a pretty interesting tip, I've never heard that before👍
  2. #12
    Old Timer fiend's Avatar
    Join Date
    May 2017
    Location
    SoCal
    Posts
    2,885
    If itís just the collar thatís seized, maybe just try to cut it off.
  3. #13
    Been Around the Block 98XJ06LJ's Avatar
    Join Date
    Jul 2017
    Location
    US
    Posts
    348
    Not sure how cold it is in Albuquerque, let mother nature give you a hand. Try the tips from earlier posts immediately after letting the Jeep sit out in the cold. Heat only the collar and the temperature variance should help with all of the previous advice.
    Also never heard of the wax trick, I'll have to try that in the future.
    Sent from my Moto Z (2) using WAYALIFE mobile app
  4. #14
    The Original Smartass piginajeep's Avatar
    Join Date
    Oct 2011
    Location
    Bear Valley Springs
    Posts
    11,091
    Quote Originally Posted by fiend View Post
    This isnít a bad idea. If you cut the collar off, I bet you cab pry the inside sleeve out. Itís cut in the middle
    2012 JK8
    1958 FC170 (Jeep Forward Control)
    1953 M38A1
  5. #15
    Been Around the Block shadowpaige64507's Avatar
    Join Date
    Feb 2015
    Location
    United States
    Posts
    439
    I had a rear upper seize up on me. I just contacted the company and they sent me a new control arm. Granted it wasn't the same manufacture as yours but might be worth a call.
  6. #16
    Nothing but a Thing nmwranglerx's Avatar
    Join Date
    Apr 2012
    Location
    Albuquerque, NM
    Posts
    1,113
    Thanks for all the suggestions. If I get a chance this weekend Iím goin to try a few things like the wax trick. Temps have been in the high 20s in the mornings so I might try the hot cold tip suggested. I could cut the collar but the way these adjusters are designed I donít think it would help. The collar is attached to a threaded rod that screwed into the control arm. Theoretically this allow for the arm length to be adjusted without removing from the axle mounting point. Incidentally I donít think they are seized due to rust but more likely due to fine particles of dirt. I could be wrong on this, but New Mexico doesnít see much rain and thereís dirt EVERYWHERE lol.
    "all roads lead somewhere" -anonymous
  7. #17
    Nothing but a Thing Coop's Avatar
    Join Date
    Jul 2015
    Location
    Ohio
    Posts
    1,927
    I gotta try the wax method. That is a new one to me.
    Sent from my iPhone using Tapatalk Pro
  8. #18
    Nothing but a Thing desertrunner's Avatar
    Join Date
    Mar 2013
    Location
    Great Falls, MT
    Posts
    1,795
    Not that it hasn't already been said but when I re did the arms on my old JK my rock krawler arms were seized just like your describing and what finally broke them loose for me was days of PB blaster heating and then I stuck the pointy end of a spud wrench in the bolt hole and beat the shit out of it with a BFH back and forth with the arm in a vice. I'm sure it wasn't easy on the joint and it was an ugly process but I eventually got them to turn. Not sure with the Evo arms if you can turn them by the joint but that's what I did
    12' 2dr Gecko Sport 6 speed
    PR44, ARBs, 4.88s, 35 spline rear, Adams 1350 Front & Rear, Rubi T-case, Rubi sway bar + Evo no limits, Evo armor & skids, 37/13.50" Cooper STT Pro, Evo 2" plush / OME med duty springs
    ***SOLD*** 08' JKU Rubicon 6-speed Stone White, 3.5" RK lift, 37" KM2s and lots more.
    ***CURRENT DD*** 16' F150
  9. #19
    Nothing but a Thing Speedy_RCW's Avatar
    Join Date
    Jul 2015
    Location
    Northern California
    Posts
    1,807
    Quote Originally Posted by nmwranglerx View Post
    Iím seeking advice as to how to unseize my rear lower control arms. Theyíre EVO adjustable control arms from their double duty long arm lift. The adjusters are completely seized and have been for some time. Iíve soaked them with PB blaster and tried a very large pipe wrench but canít get them to turn. I also tried using a torch on them but itís just a cheap-o one from Home Depot. I have the old style collars that use spammer wrench to turn so a standard crescent wonít work. I would like to switch these collars out with the new hex style ones. EVO sells replacement arms but they are $400 each. Any thoughts? Should I invest in a bigger torch? Put them in the oven? Lol. The Johnny joints are twisted and seized in opposite directions either end.
    Curious if you ever got this apart and if you tried to wax method?
  10. #20
    Join Date
    Apr 2012
    Location
    Albuquerque, NM
    Posts
    1,113
    Iíve been to busy with work to try yet. I might have time this weekend. Iíll post up results afterwards.
Similar Threads
  1. Advice needed
    By MSJKU11 in forum Jeep JK Wrangler
    Last Post: 09-23-2017, 03:08 AM
  2. Advice needed
    By gafirefighter20 in forum Jeep JK Wrangler
    Last Post: 02-01-2015, 07:25 PM
  3. Advice Needed!
    By Almost JKU-ing in forum Jeep JK Wrangler
    Last Post: 12-06-2014, 03:39 PM
  4. Control arm adjuster seized
    By Strike Force Zebra in forum Jeep JK Wrangler
    Last Post: 08-11-2014, 07:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
