Results 1 to 10 of 10
Thread: Misfire
  1. #1
    Been Around the Block krdadlamb's Avatar
    Jun 2016
    Utah
    331
    Misfire
    I have a 98 XJ with the 4.0. Running rough. Throwing misfire codes. I've changed the coil, distributor cap, rotor, plugs, wires and O2 sensor. If anything it's running worse. The only thing I can think of is the timing chain since it has 224,000 miles. Anyone have any ideas before I tackle the big job of changing the chain?
  2. #2
    Old Timer wjtstudios's Avatar
    Nov 2016
    Rochester, MI.
    3,970
    Quote Originally Posted by krdadlamb View Post
    It’s been awhile since I’ve been around one, but they ran a vacuum system, correct? Have you checked for any vacuum leaks? That could definitely be a factor if it does.
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
  3. #3
    Jun 2016
    Utah
    331
    Quote Originally Posted by wjtstudios View Post
    I haven't checked anything to do with the vacuum. My reason for leaning towards the chain is the rotor post is clearly only firing on one end, not getting a good contact all the way across. I know the chains are known for stretching, so....
  4. #4
    Knows a Thing or Two Scrambler's Avatar
    Jul 2015
    GA
    649
    Check fuel pressure as well.
  5. #5
    Nov 2016
    Rochester, MI.
    3,970
    Yeah, good point. I was thinking vacuum advance on the timing. But that wouldn’t explain the rotor post.
  6. #6
    Jun 2016
    Utah
    331
    As I stated, I replaced the rotor and cap, but not the entire distributor nor the cam position sensor. Would either of those make any difference or should I just accept the fact I've got to tear into it and replace the chain?
  7. #7
    Nov 2016
    Rochester, MI.
    3,970
    I hate to have you throw parts at it, but all three I would guess would cause the misfire. I don't know enough about that engine to say for sure, it would be a hell of a lot easier to try a new distributor and or a cam sensor first before you tear it down. Nothing worst tearing the engine down to do the chain to find out it was one the other two!! I wish I could be of more help, good luck.
  8. #8
    Jun 2016
    Utah
    331
    Update
    I went ahead and did the timing chain, it was definitely stretched. But didn't fix the problem. So I checked the compression. Started on cylinder 1, it only had 50, 2 had 120, 3 didn't even register, so I quit. I'm hoping it's just valves and not a piston.
  9. #9
    Nothing but a Thing Snboarder113's Avatar
    Oct 2015
    michigan
    1,115
    Was it knocking or slapping?
  10. #10
    Nov 2016
    Rochester, MI.
    3,970
    Yeah, that’s not going in the right direction. Good luck
Similar Threads
  1. Cylinder 2 misfire
    By Tan2TheMan in forum Jeep TJ & YJ Wrangler
    Last Post: 05-30-2017, 12:36 PM
  2. cylinder 4 misfire!
    By srosario in forum Jeep JK Wrangler
    Last Post: 05-10-2017, 02:35 PM
  3. P0300 misfire help
    By JDMstealthToast in forum Jeep JK Wrangler
    Last Post: 09-21-2016, 03:59 AM
  4. Cylinder misfire
    By titus7 in forum Jeep JK Wrangler
    Last Post: 02-03-2015, 07:53 AM
  5. Cylinder 4 misfire
    By Hobolobo in forum Jeepin Life
    Last Post: 01-21-2014, 04:24 PM
