Results 1 to 9 of 9
Thread: Melted power plug on ARB compressor
  1. #1
    Nothing but a Thing nmwranglerx's Avatar
    Apr 2012
    Albuquerque, NM
    1,066
    Noticed this the other day when I had to disconnect the power plugs to my ARB single air compressor.
    Female connection looks fine but the male part is definitely melted.
    A quick internet search using ďARB melted power connectionsĒ showed Iím not the only one to have this happen. Iím wondering what the best solution is and if anyone on WAL has tackled this issue before.
    "all roads lead somewhere" -anonymous
  2. #2
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    25,755
    I've seen this close to a hundred times on GM blower motor connections. To the best of my knowledge, there really isn't a fix. The motor/pump draws enough amperage to heat up the circuit to melt the plastic connector. As long as the plastic still insulates the circuit, it serves its purpose. I haven't heard of this on an arb compressor though. On the GM issue, you just replace the damaged parts, but they're not updated or anything so it could happen again.
  3. #3
    Apr 2012
    Albuquerque, NM
    1,066
    Huh, thatís interesting. I guess Iíll just get some heavier duty connectors and swap the ARB ones out. The compressor is still working but it makes me nervous to see something electrical in that condition and in the engine bay. I use the shit out of that compressor but when I air up tires, the hood is always up and the Jeep is running. Of course, wheeling in the southwest during the summer, itís not uncommon to have temps pushing upper 90s. I canít imagine what the engine bay sees temperature wise during those times.
  4. #4
    Old Timer wjtstudios's Avatar
    Nov 2016
    Rochester, MI.
    3,531
    Quote Originally Posted by nmwranglerx View Post
    It might be time to upgrade to a twin! They at least have a fan to cool the internal wiring and pumps. I couldnít imagine the temps either.
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
  5. #5
    Nothing but a Thing QuicksilverJK's Avatar
    Apr 2016
    Reno NV
    1,342
    The plug is an area of resistance. As the compressor runs it heats up there because of the amperage being drawn through it. There are 2 good fixes in my opinion.
    1 replace that plug for one that is rated for higher amperage.
    2 hardwire and forget the plug.
    I personally would hardwire and hear shrink to keep moisture out of the connection area.
    Also, if you blow a fuse on that or any circuit don't just throw a bigger fuse at it. The problem isn't that the fuse is too small, the problem is that the circuit is operating outside of its design limits.
  6. #6
    Fresh Catch GeoWillys's Avatar
    Apr 2017
    Ohio
    7
    Since only the one half of the connector seems to be melted I would venture to say that particular end has a poorly crimped connection. The same amount of current traveled thru both pieces but only the one with resistive connection got hot enough to melt it.
  7. #7
    Apr 2012
    Albuquerque, NM
    1,066
    Quote Originally Posted by QuicksilverJK View Post
    Thanks for the informative post. I ordered some Anderson connectors that are rated at 45a. Iím also considering the hardwire route. In case anyone is wondering, all the connectors are factory ARB and I havenít altered the harness in any way. Itís also connected to the battery per ARBís instructions. Itís been a reliable source of air for my front locker and airing up tires. I really donít think it was designed to air up 37 in. tires or at the very least, that is pushing it to its limits.
  8. #8
    Apr 2012
    Albuquerque, NM
    1,066
    Quote Originally Posted by GeoWillys View Post
    Yea, I thought that was strange it only affected half. As far as the crimp goes, IDK, it came from the factory with those connectors, if I recall correctly.
  9. #9
    Apr 2012
    Albuquerque, NM
    1,066
    Quote Originally Posted by wjtstudios View Post
    Yea, a twin would be nice but Iím currently saving for a much bigger upgrade to my Jeep .
Similar Threads
  1. Jeep jk power locks and power windows
    By TheBlueJeep in forum Jeep Builds
    Last Post: 02-07-2018, 10:43 PM
  2. Melted fuse box, what could cause this?
    By WJIN4LO in forum Jeep Cherokee & Grand Cherokee
    Last Post: 08-29-2017, 03:30 AM
  3. Replacing Manual Doors with Power Window power Lock Doors-
    By Nicalife in forum Jeep JK Wrangler
    Last Post: 07-05-2016, 09:16 PM
  4. Melted wires
    By Mikead40 in forum Jeep JK Wrangler
    Last Post: 01-08-2015, 11:14 PM
  5. Warn Power Plant or ARB twin compressor
    By steadfast91 in forum Jeep JK Wrangler
    Last Post: 11-05-2014, 03:05 PM
