Hey! So after awhile the latch for the drivers door doesn't register that the door has opened so the stereo doesnt turn off immediately.
I can manually reach over to the latch and press the upper piece up and then it works.
I've shot WD40, grease, etc and no dice.
Last night I used an Allen wrench and loosened up the adjustment bolt counterclockwise and worked the handles a bit, slammed the door a few times etc but that doesnt seem to change the upper arm position at all?
Just seeing if anyone seen a trick to fixing this rather then earing the door apart and replacing the whole assembly?
