Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 54
Thread: Trailer build
  1. #21
    Been Around the Block Webe's Avatar
    Join Date
    Apr 2013
    Location
    Montana
    Posts
    390
    Nice welds. I like the idea of the telescoping tongue. The trailer looks beefy enough to haul all the Jeep parts for everyone in the run.
  2. #22
    Been Around the Block Spazbyt's Avatar
    Join Date
    Oct 2015
    Location
    St.Peters, MO
    Posts
    363
    That will be one tough trailer. Well done.
  3. #23
    Caught the Bug dytrdr5's Avatar
    Join Date
    Jan 2017
    Location
    Houston
    Posts
    88
    Trailer build
    Thanks guys, I did overbuilt it a bit. It has 1/4 inch shackle mounts and leaf spring brackets, plus I didnít show you guys that every crossmember is gusseted. A42D9A5C-40A3-4020-A55A-348F30EED2C6.jpg
    Sent from my iPhone
  4. #24
    Knows a Thing or Two Abntroop's Avatar
    Join Date
    Jan 2019
    Location
    Carson City, NV
    Posts
    545
    Quote Originally Posted by dytrdr5 View Post
    Sent from my iPhone
    Nice!!! Consider dumping the leaf springs and check out timbren independent. Makes the trailer so much more pleasant to pull regardless of loaded or unloaded. That build is nice enough to warrant it.
    Matthew Nicholas
    The Wampa- 16í JK Rubicon Hard Rock
    Jeep parts and accessories purchased through the RECOMMENDED-Jeep-Parts-amp-Accessories section of this forum will help support this forum and at no cost to you.
  5. #25
    Hooked sunnysideup's Avatar
    Join Date
    Mar 2013
    Location
    Montana
    Posts
    186
    looks good!
    Waiting on final pics... great looking trailer!
    God's area code is 406!
    PastorJohnMontana
  6. #26
    Join Date
    Jan 2017
    Location
    Houston
    Posts
    88
    Trailer build
    Quote Originally Posted by Abntroop View Post
    I thought about doing that but I didnít go that route for a couple of reasons
    1. Leaf springs and solid axles are super simple and spare parts can be sourced just about anywhere.
    2. Cost, the timbrens are pretty expensive compared to leaf springs
    3. The trailer rides very nice because itís not riding on 3500 lb trailer leaf springs, itís riding on 2.5 lift heavy YJ leaf springs. These things are 48 inches long and are the perfect spring rate for an overlanding trailer. It doesnít hop or skip down the road and just absorbs bumps really well but have the capacity of not being easily overloaded.
    Thank you for the kind words on the build
  7. #27
    Join Date
    Jan 2019
    Location
    Carson City, NV
    Posts
    545
    Right on! Good to know. All the builds Iíve seen and the complaints involve the bounce from the 3500 lb springs, I know the ones that were originally on my bantam were terrible as well for that. I assumed thatíd be the case across the board symptomatic of leaf springs in general. Would love to see yours in action. learn something new every day!
    Matthew Nicholas
  8. #28
    Join Date
    Jan 2017
    Location
    Houston
    Posts
    88
    Thatís the exact same thing I heard about the 3500 lb leaf springs, they are way too stiff for a 1200 lb trailer loaded and on top of that they are only 25 inches long, so they donít flex very well. They are just not a good option for an off-road trailer. People use them because they are $40 for a pair instead of $200-$300 for YJ or Tacoma leaf springs. I also cut the leaf spring tabs off of the axle and replaced them with Barnes 4 wheel drive 1/4 inch thick bracket and fully welded them inside and out. 2D21F4EE-781E-4904-8B50-ADA34977B7AB.jpgD378A894-38ED-4285-8E8A-A81D6CF99A80.jpg
  9. #29
    Join Date
    Jan 2019
    Location
    Carson City, NV
    Posts
    545
    Trailer build
    Rad! that looks good
    The Timbrens I added ride so well. I figure the trailer is so far under the weight spec they should last a long time. Been several years now and they seem to be holding up well. Will be curious to see how they do in another few years.
    Matthew Nicholas
  10. #30
    Caught the Bug mjr11's Avatar
    Join Date
    Sep 2012
    Location
    PA
    Posts
    57
    Looks great!
Similar Threads
  1. Trailer Build For My Jk
    By 07streetbobrider in forum Jeep JK Wrangler
    Last Post: 06-04-2018, 05:14 AM
  2. Future Trailer Build (maybe)
    By bruggymonster in forum General Jeep Stuff
    Last Post: 09-03-2015, 12:52 PM
  3. Trailer build?
    By P1TBU11 in forum General Jeep Stuff
    Last Post: 07-10-2015, 03:40 PM
  4. Off road-ish trailer build
    By my_jk in forum Jeep Show & Tell
    Last Post: 05-07-2015, 05:42 PM
  5. Off Road Trailer Build
    By Moho in forum Member Jeep Builds
    Last Post: 12-04-2012, 01:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
