Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 89
Thread: Ordered long arms, but questions about what else I need
  1. #61
    Caught the Bug KevinG's Avatar
    Jan 2019
    Sudden Valley Washington
    72
    Quote Originally Posted by Jsouder53 View Post
    Looking good man! One day I’ll get around to getting that setup
    Thanks! I'm sure you probably know this but you live in a beautiful area. We went through there when we moved back here from the east coast. Thanks again for the comment!
  2. #62
    Jan 2019
    72
    So I spent about another hour grinding and test fitting the drivers side rear bracket then my wife and daughter got home. Then work called and had to run in which took the rest of the afternoon. Just spent another hour cleaning up. Brackets are in place.
    And here’s the carnage
    Hopefully I’ll be able to button up the back tomorrow night after I get home from work.
  3. #63
    Old Timer TrainWreck618's Avatar
    Oct 2015
    East of St. Louis
    2,794
    Quote Originally Posted by KevinG View Post
    Looks good are you welding these in?
  4. #64
    Been Around the Block bhaner's Avatar
    Jul 2017
    Wickersham, Wa
    295
    Nice! Looks good!
    Little tip with sawzall blades to save you some money... Run them as slow as you can. Wide open heats up the blade and will actually melt the teeth off. Once you start to see sparks it's all over.
    Byron Haner - Wickersham, Wa
    -Currently Building-
    2016 JKUR HR
    Evo Offroad DTD w/Evo Lever
    Dynatrac Elite ProRock XD60/80
    40" Procomp MT, 17" B.A.D. Wheels
    My Build Thread
  5. #65
    Jan 2019
    72
    Quote Originally Posted by TrainWreck618 View Post
    I was actually going to bolt in. I have a pretty light duty welder so I had thought about welding and bolting, but I'm a pretty novice at best welder. I may leave them bolted for a while to see how bad I abuse the rear lower control arm mount. If I feel I'm beating them up or they are hindering me, I may see if I can buy the hi clearance mounts and see if the guy that commented below you will help me get 'em on.
    Quote Originally Posted by bhaner View Post
    Nice! Looks good!
    Where were you 5 blades ago????!?!?
  6. #66
    Jul 2017
    Wickersham, Wa
    295
    LMAO!
    2016 JKUR HR
    My Build Thread
  7. #67
    Oct 2015
    East of St. Louis
    2,794
    They are bolt on but I recommend welding them in for sure. The lower mounts haven’t hung up on me too bad yet, but they do definitely hang lower than the high clearance. If they cause you too much trouble just get bigger tires
  8. #68
    Jan 2019
    72
    Yeah, I'll probably see what I can do about that afterwards. I know I am creating more work for myself, but it's not a big deal to bolt and then weld is it? Thanks for the vote of confidence with them not hanging up too bad, but I'm sure 40's would help.
  9. #69
    Jul 2017
    Wickersham, Wa
    295
    Will work just fine. I bolted and welded mine.
    2016 JKUR HR
    My Build Thread
  10. #70
    Jul 2017
    Wickersham, Wa
    295
    The high clearance mount is quite a bit different than yours.
    I was fairly impressed.
    2016 JKUR HR
    My Build Thread
Similar Threads
  1. Replies: 9
    Last Post: 02-20-2019, 07:57 PM
  2. Replies: 34
    Last Post: 06-13-2017, 10:45 PM
  3. Short arms vs long arms
    By whispike in forum Jeep JK Wrangler
    Last Post: 10-11-2016, 09:54 PM
  4. Fitting 37"s - 3.5" Coil lift w/ factory control arms vs. Long arms
    By Mike_JK_Houston_711 in forum Jeep JK Wrangler
    Last Post: 05-27-2016, 11:25 PM
  5. Ordered a 2016 JK. Questions.
    By Helwyr in forum Jeep JK Wrangler
    Last Post: 04-14-2016, 01:44 AM
