Page 16 of 23 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 228
Thread: OBD JScan - Program With Your Smart Phone
  1. #151
    Old Timer Arrcherr's Avatar
    Aug 2017
    Palos Hills
    2,703
    Quote Originally Posted by sipafz View Post
    Got the backup camera installed into the Wife’s KK:
    Attachment 328233
    Attachment 328234
    Attachment 328235
    Would’ve thought that she’d be more excited, but it was more like “glad you’re done, you grilling dinner now”.
    I tell ya what, if ya come over and install mine I'll grill dinner for ya
  2. #152
    Old Timer sipafz's Avatar
    Mar 2015
    Saukville, Wisconsin
    2,592
    App updated to version 3.1 at least for iOS. Noticed some new adaptations that I might mess around with:
    AC on/off - Not sure why you would want to disable, but it’s an option.
    DRL - New High Beam at 50% setting. I’m not interested in this new setting. I wish they could activate the parking lights as a DRL. I contacted the developer about it, but was told that it wasn’t possible .
    Fog Lamp Drop Out - Not new, but I haven’t been able to get this deactivated on the Wife’s KK. Been back a forth with the developer a couple times. Maybe this update will fix it?
    HFM UConnect Handsfree On/Off
    Seatbelt Alert On/Off
  3. #153
    Fresh Catch
    Jul 2019
    Michigan
    1
    Hi all,
    Wondering if you could help advise me on something.
    I picked up an 08 JKU, that had origins in Canada. The headlamps are stock, and Canada has DRL as mandatory, so they're operating at the 50% voltage (not sure if its high beams or regular).
    After searching around for a while, I ordered some LED Headlamps (and fogs) on Amazon that got pretty decent reviews. I believe there will be an issue with the DRL being active on the computer with the headlamps. I'm trying to be proactive and order what I may need all at once to combat this.
    So far, I ordered:
    Headlamps/Foglamp LED kit
    DRL Wiring Adapter Hardness kit
    Anti Flicker Harness Kit
    Veepeak OBDCheck OBD2 Scanner (For JScan App)
    I kind of got an idea on what to do. Would it make the most sense to use Jscan to disable DRL completely and just use the harness I bought? Or can I not disable it completely, and switch it to fog lights (I've read other posts on forums that mention this.) Or do I not need the harness, and perhaps change the voltage of the DRL to 100%?
    I'm just trying to wrap my head around this before I start to tackle it.
    Thank you all in advance!
  4. #154
    Fresh Catch
    May 2019
    Qld
    3
    This is a list of current updates, seems to be evolving nicely, Hoping for EGR delete for my diesel soon
    Attached Images Attached Images
  5. #155
    Mar 2015
    2,592
    Quote Originally Posted by Data View Post
    Hi all,
    So far, I ordered:
    Wave from the Northern Milwaukee Burbs . Welcome to Wayalife! It’s best to introduce yourself to the group so here is a link:
    Give us a Wave
    https://wayalife.com/forumdisplay.php?f=11
    Why? Because the new lights are LED? Your new lights will be fine with DRL active or you can use the JScan app to disable completely or switch DRL to blinker lights.
    I have LED lights and had DRL active on the fog lights for awhile. I also tested the low beam / high beam 50% DRL and they both worked, I just preferred the blinker DRL so that’s what I run.
    I’m surprised that your new lights didn’t come with an anti-flicker harness. These days most manufacturers include that built right into the H4/H13 adapter harness. I don’t know what the DRL wiring adapter harness is. I’m guessing that you won’t need that.
    Good luck and let us know how it turns out.
  6. #156
    Knows a Thing or Two Wethy's Avatar
    May 2014
    Ontario
    732
    since you have ordered the anti flicker harness you should be okay. And not need to do anything other than put it in the correct spot. However if you still get flickering issues then go for something like the JScan app. It can set the DRL to low beam at full voltage or highbeam as well and other lights as well.
    Also up here in canada the DRL signal is the highbeam at 50%voltage. So most LED headlights will have the highbeam on during day so id recommend even if you dont have flickering issues to use the Jscan app to swap it to The low beam, or off if your state doesnt require to run DRLs like canada does you can just turn them off.
    I know prior to my projector retrofit i had LEDs and thats how they were.
    '14 JK Sport Anvil 6-Spd 3.73 gearing
    Installed:
    -Rubicon Express 2.5" lift with monotube shocks
    - Cobra Cb 18 WX STII
    - 285/70/17 Duratracs
    - 1.5" G2 Wheel Spacers
    - Rigid Dually Spots
    - Poison Spyder A-Pillar Mounts
    -RC 2.5" swaybar disco's
    Awaiting Install:
  7. #157
    Been Around the Block sm31's Avatar
    Nov 2012
    Eagle River, AK
    302
    This is ignorance on my part but my jeep came from Vancouver. Until now I was unaware there were any differences. I just plugged in my no-name Amazon headlight/fog light kit (which has delivered impressive performance for nearly a year) and away I went. No problems whatsoever.
    I'm also a very satisfied OBDJscan customer. I originally bought it to re-calibrate the speedo for larger tires & install a backup camera... but I also use my fogs as DRL's. Works great!
  8. #158
    May 2014
    Ontario
    732
    Quote Originally Posted by sm31 View Post
    Really other than the gauge cluster and DRLs . I believe most newer vehicles have them now even in the states. But canadian vehicles have had to have them since the early 90s.
    Installed:
    Awaiting Install:
  9. #159
    Fresh Catch shogun's Avatar
    Oct 2018
    NY
    29
    Worked well
    This app and an inexpensive Bluetooth adapter worked great for me, I went from 3.21s to 4.88s with 37s but I didn't have a working procal so I drove home and went into limp. After getting my phone and the adapter paired, and watching the YouTube tutorial, I had the gear ratio and tire size set within about 3mins. Beats the hell out of flicking tiny switches. Also cleared the code for incorrect gear ratio prior. I gotta say I wouldn't have believed the functionality was this good had I never used it.
  10. #160
    Old Timer USMC Wrangler's Avatar
    Feb 2015
    Cochise County, AZ
    4,207
    I saw someone mention the other day that they centered their steering wheel with JScan. I gave it a try today and am impressed.
    Since adding an aftermarket draglink and doing a flip with my 4” lift I’ve played hell trying to center my steering wheel. It’s dead nuts center now!
    2013 JKU Sport "Spider" with some EVO goodies and a chop here and there
    Overall "build thread" http://wayalife.com/showthread.php?2...ker-quot-build
Similar Threads
  1. Can anybody give me working XEvil program???
    By XEvilBestalbup in forum The INFIRMARY
    Last Post: 12-08-2018, 08:55 PM
  2. AEV Program and HOTOIL message
    By BobNH in forum Jeep JK Wrangler
    Last Post: 10-06-2018, 03:12 PM
  3. Wanting to program but suspect I may be already
    By TERAS in forum Jeep JK Wrangler
    Last Post: 04-02-2018, 05:26 PM
  4. New spark program
    By tapcola in forum Jeep JK Wrangler
    Last Post: 01-02-2014, 05:29 PM
