Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Never starts first time
  1. #1
    Fresh Catch
    Mar 2019
    Marana, AZ
    5
    01 sport 4.0 rarely if ever starts on the first try but almost always on second. I get misfire codes on random cylinders. My question is should I start with just replacing plugs before looking into coil pack? Is there something else I should look at first?
  2. #2
    Nothing but a Thing QuicksilverJK's Avatar
    Apr 2016
    Reno NV
    1,421
    Have you tried keying up to run position for a few seconds, then back to off, then start? This would allow the fuel pump to re prime the system before your first start attempt. I am leaning towards possible fuel pump or injector bleeding off.
    If that doesn’t work I would have you check for spark on first try, but I’m pretty sure you have the coil rails that sit directly on the plug and I don’t know of a way to verify spark on that one.
  3. #3
    Fresh Catch
    Aug 2016
    Laguna Hills CA
    30
    I usually turn the key to the run position for 3- 5 seconds before I crank to start with mine. 2003 4.0
    Might be like what Quicksilver is saying - possible fuel pump or injector bleeding off
  4. #4
    Fresh Catch
    Mar 2019
    Marana, AZ
    5
    Quote Originally Posted by QuicksilverJK View Post
    Quote Originally Posted by nujeeper View Post
    Thank you for your responses but yes I
    have tried both turning the key on and off several times as well as turning key and waiting several seconds before starting. Neither of those make a difference except I learned you can get check engine codes on your odometer. I get a check engine light every few days and it’s usually a misfire on cylinder random #. I have a CE light now I will check it to see.
  5. #5
    Fresh Catch
    Mar 2019
    Marana, AZ
    5
    The CE light is random multiple cylinder misfire detected with pending codes misfire on cylinder 1 & 2. I have OBD II reader and I can gather live data but I not sure which reading I should be watching to get more info if anyone knows that?
  6. #6
    Nothing but a Thing Strodinator's Avatar
    Apr 2017
    Oregon
    1,219
    Quote Originally Posted by Jackietaz View Post
    Start with spark plugs and I'd pick up a quality spark tester as well.
    Sent from my PH-1 using WAYALIFE mobile app
    If you want to see a broke college kid struggle through an LS swap, then here's your chance: https://wayalife.com/showthread.php/...546#post956546
  7. #7
    Fresh Catch
    Mar 2019
    Marana, AZ
    5
    I picked up plugs today and my friends shop said they will check out the coil pack sometime next week. I will post solution when I get it figured out. Thanks
  8. #8
    Hooked G-mansjk's Avatar
    May 2017
    Ca
    129
    Honestly throwing plugs at it might take care of your misfire code and starting issue.. it's the cheapest place to start. No need for testers, pull the fuel relay, take each plug out one at a time and lean it against the block and have someone crank. If you don't see spark than the start looking into other possible issues.
  9. #9
    Apr 2016
    Reno NV
    1,421
    I look forward to hearing what the solution ends up being.
  10. #10
    Apr 2016
    Reno NV
    1,421
    Quote Originally Posted by G-mansjk View Post
    Pretty sure this year 4.0 had the coil on plug setup. Basically a rail that bolts down onto the plugs, no wires at all.
Similar Threads
  1. Starts Fine/ Won't Start
    By Bhill1600 in forum Jeep JK Wrangler
    Last Post: 01-21-2018, 12:56 AM
  2. Starts but won't stay on
    By chefant in forum Jeep TJ & YJ Wrangler
    Last Post: 10-07-2017, 02:27 PM
  3. Today starts a new chapter!
    By Speeddmn in forum The 8th Slot
    Last Post: 06-15-2016, 08:22 PM
  4. Jeep starts and then dies
    By yjheep in forum Jeep TJ & YJ Wrangler
    Last Post: 04-04-2016, 11:57 AM
  5. Build starts tomorrow!
    By Wombat in forum Member Jeep Builds
    Last Post: 09-16-2015, 02:21 AM
