Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Death Wobble
  1. #1
    Fresh Catch
    Nov 2018
    Missouri
    5
    Death Wobble
    I’ve recently put new steering components along with new ball joints on my ‘02 Wrangler, it has a 4” lift on 35”tires,I took it today to finally get it aligned and developed a case of death wobbles. I changed the pan hard and shimmy shock and it’s still there. Im looking for a place to start looking if anyone has any fresh ideas. Thank you for any input.
  2. #2
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    30,907
    Welcome to WAYALIFE. Make sure all bolts are torqued properly since the symptom didn't exist prior to the new work.
    "When the government fears the people, there is Liberty. When the people fear the government, there is tyranny."
  3. #3
    Fresh Catch
    Nov 2018
    Missouri
    5
    Death Wobble
    Everything was done properly ( I was in the shop with the tech) we tried neutral toe along with in and out to a safe degree with the same results even spin balanced both front tires.
  4. #4
    Sep 2015
    Colorado
    30,907
    For death wobble to occur, there has to be play somewhere. Possibly even an elongated bolt hole where the track bar mounts.
  5. #5
    Nothing but a Thing Snboarder113's Avatar
    Oct 2015
    michigan
    2,236
    Quote Originally Posted by IronPig2 View Post
    If everything was done right... it wouldn’t be broken. Take it back.
  6. #6
    Fresh Catch
    Nov 2018
    Missouri
    5
    Could cross over steering be an issue?
  7. #7
    Been Around the Block Bustedback's Avatar
    Apr 2015
    NorCal
    378
    Are the track bar and drag link angles the same? If they’re not parallel you will get death wobble.
    Typed by my very own fat fingers on my iPad or iPhone.
  8. #8
    Fresh Catch
    Nov 2018
    Missouri
    5
    Quote Originally Posted by Bustedback View Post
    Not exactly but not over a degree or two different
  9. #9
    Old Timer jdofmemi's Avatar
    Mar 2018
    Menifee CA
    3,071
    Did you check that every bolt is properly torqued?
    Also, check the holes the track bar bolts too for any sign they are oblong.
    You have to drop the track bar to check.
    As said by others, something you changed is likely not quite right.
  10. #10
    Fresh Catch
    Nov 2018
    Missouri
    5
    Quote Originally Posted by jdofmemi View Post
    The only thing changed initially was just the toe and as I stated all of them parts were replaced with less than 100 miles on them before the alignment the wobbles started after the alignment. Nothing else was touched at first.
Similar Threads
  1. Replies: 224
    Last Post: 03-08-2020, 06:53 PM
  2. Death wobble help
    By Jeeper125 in forum Jeep JK Wrangler
    Last Post: 03-12-2019, 06:56 PM
  3. Death wobble
    By nightcrawlerjk in forum Jeep JK Wrangler
    Last Post: 05-13-2017, 11:52 PM
  4. ...Death Wobble......Again....
    By Deathmask in forum Jeep JK Wrangler
    Last Post: 04-13-2017, 03:35 PM
  5. Death wobble?
    By 98chilipepperxj in forum Jeep JK Wrangler
    Last Post: 03-05-2017, 10:58 PM
