Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Unit Bearings -75,000 miles?
  1. #1
    Old Timer USMC Wrangler's Avatar
    Feb 2015
    Cochise County, AZ
    3,729
    I have about 40,000 miles on 35ís and 4.5Ē backspaced wheels. Iíve been chasing a flighty steering sensation, not bump related or death wobble, for a couple months now. Iíve already installed ProSteers and an Exodus Jeeps tie rod in the past month and a new drag link is inbound from Ruffstuff. Thereís definitely play at the pitman arm end of my OE DL. I also have two collapsed .75 coil spacers causing my springs to bow. That will be remedied Friday.
    As I walked out to my Jeep today it looked as if my front tires had a great deal of camber. Sorry for the crappy picture. Are you seeing what I am? Am I overreacting?
    Later tonight I went over a series of speed bumps at about 10 mph. Each time my traction control light flashed once. I watched for it to flash again on the drive home, nothing, but no large bumps to speak of like the speed bumps.
    Best explanation I can give...sometimes it drives straight and smooth. Sometimes Iím sawing on the wheel like a madman to try and keep it between the lines. 50-70 mph is the scariest and if thereís a crosswind, Iím getting one hell of a workout. Again, Iíve really paid attention when it happens if itís related to a bump, but so far thatís a no. If I understand things correctly, I do feel almost a dead spot in the middle-ish of the steering cycle and that can be related to the DL slop. I recently checked all my torque settings on all suspension at both ends and steering components. Everything was good. My wife and daughter refuse to drive it because ďitís all over the placeĒ as they describe it.
    My latest guess are unit bearings from the ďlookĒ of the front tires and the weird TC light flash. I donít hear any unusual noises. Front lower CAís are RK adjustable, uppers are OE, track bar is OE. Anything else Iím missing?
    2013 JKU Sport "Spider" with some EVO goodies and a chop here and there
    Overall "build thread" http://wayalife.com/showthread.php?2...ker-quot-build
  2. #2
    Addict Ddays's Avatar
    Aug 2015
    Darlington, Pa
    8,296
    Easy way to check the Unit bearings is to jack up front end and try to move the whole wheel. Hold on at the top and bottom and see if you get any movement.
  3. #3
    That dude from Mississippi notnalc68's Avatar
    Jan 2015
    Madison, MS
    13,836
    They are probably gone. Mine were, at around that many miles. The symptoms were about the same.
    Build Thread-- http://wayalife.com/showthread.php?3...l-II-The-Deuce
  4. #4
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    26,994
    Check your toe also, sometimes that can make the tires look like improper camber. I would definitely change that drag link you spoke of first, then re-diagnose.
  5. #5
    Old Timer fiend's Avatar
    May 2017
    SoCal
    3,142
    Unit bearings and/or ball joints. Or maybe youíll find that your knuckles are done. That happened to me. One of the symptoms was noticeable camber similar to yours. IMG_0330.jpg
  6. #6
    Feb 2015
    Cochise County, AZ
    3,729
    Thanks guys. My toe was just dialed in a couple weeks ago as well.
    The traction control light is what sent me searching on here. I couldnít find that symptom explained exactly the same, but I saw where some had posted definite failures and lights coming on.
  7. #7
    Feb 2015
    Cochise County, AZ
    3,729
    Quote Originally Posted by fiend View Post
    I remember seeing that! I looked my knuckles over too, but nothing jumped out. ProSteers went in last month.
  8. #8
    Knows a Thing or Two Gbint's Avatar
    Dec 2017
    Victoria B.C.
    506
    My front tires sit exactly like that. Has been since new. Always looked a bit out, however tire wear is perfectly even.
    if it ain't broke!
  9. #9
    Feb 2015
    Cochise County, AZ
    3,729
    Quote Originally Posted by Gbint View Post
    So far, tire wear looks good. At 40k on these Nittos and religious 3k rotations Iím pretty happy with them. I suspect Iíll be replacing these soon.
    Again, I might be over thinking this and will reassess after the DL gets replaced.
  10. #10
    Jan 2015
    Madison, MS
    13,836
    Quote Originally Posted by USMC Wrangler View Post
    I had the light coming on, intermittently. I would not get any actual limp or other traction control problems. Just the light. Cindy suggested unit bearings, and that solved it.
Similar Threads
  1. South Korean Timken Unit Bearings
    By JoeB-JKURX in forum Jeep JK Wrangler
    Last Post: 07-18-2018, 10:50 PM
  2. Timken - Unit Bearings
    By wayoflife in forum Axles & Drivetrain
    Last Post: 01-13-2018, 05:52 PM
  3. Replies: 2
    Last Post: 11-05-2015, 09:12 PM
  4. unit bearings OK to reuse
    By Clark Collins in forum Jeep JK Wrangler
    Last Post: 11-18-2014, 06:32 PM
  5. Dana 30 set-up bearings for diff carrier bearings
    By Idaho 51 in forum Wanted (Active Members ONLY)
    Last Post: 11-29-2012, 12:34 PM
