Results 1 to 10 of 10
Thread: Tire inflator with pressure gauge? (like the one in Eddy's videos) :)
  1. #1
    Been Around the Block sm31's Avatar
    Nov 2012
    Eagle River, AK
    311
    Having trouble finding a good inflator setup like Eddy uses. I really want the longer hose for safety (and for my back) but the ones I have found only have hoses about 18" long. Is that a custom setup or am I just not looking in the right places? Thanks!!!
  2. #2
    Old Timer jdofmemi's Avatar
    Mar 2018
    Menifee CA
    3,025
    I am not sure what Eddie has, but here is what I did.
    First pic is what I have used for years that came with my Power Tank.
    It works good, but I was tired of holding the handle, plus the hose was not long enough to stand, and my knees don't like to crouch down for long.
    Second pic is what I made up. It is mostly Harbor Freight with a good gauge from Amazon. I did several versions of this before I got to what I am mostly happy with. All told, I have just under $30 in it.
    The first one I made had a longer hose, and it was too long. I also had a swivel fitting, until I found out how small the ID was and how much flow it restricted.
    The current version has a 3' hose, clip on straight air chuck, and two ball valves on a tee. I tried it with just one valve, but the gauge was not happy with the 200 psi from the Power Tank.
    This set up will rest on the tire, and stay there, while you stand and check air. You have to close the supply and open the gauge valve to check, but that is super easy to do.
    I used a quality 0-60 psi gauge, so it is easy to read. My first one I used a liquid filled gauge. I don't recommend that, it leaks the liquid out. I think I blew a seal when I used it with the Power Tank, before I added the second valve.
    In the close up, you can see how it goes together.
    Bonus is it also works as a handy deflater.
    Attached Images Attached Images
  3. #3
    Been Around the Block jjlong's Avatar
    Apr 2015
    SoCal
    462
    That's a nice little set up, Jerry! I may have to steal your design.😎
  4. #4
    Nov 2012
    Eagle River, AK
    311
    Quote Originally Posted by jjlong View Post
    Same here!!! That is fantastic!!!
    I was airing up beadlocks I had just mounted yesterday... Had my ear and eye protection on but I guess I felt a little of what the bomb disposal guys must feel as I sat there virtually hugging the tire to hold the inflator in place. Not fun at all...
  5. #5
    Mar 2018
    Menifee CA
    3,025
    Thanks, and no need to steal it, I will gladly share😉
    Quote Originally Posted by sm31 View Post
    I know what you mean. I finished this in time for mounting my new tires on the beadlocks.
    I aired them enough to seat the bead with my Power Tank, then finished them with my little puff puff compressor, since my tank was nearly empty.
    I was able to just let it run, and stay far enough away to not have to think twice about it.
  6. #6
    Knows a Thing or Two RCVRY's Avatar
    Jun 2017
    NWI Region Rat
    859
    I’ve got a Jaco Flowpro digital and really like it. It screws onto the valve stem so I don’t have to hold it, and the large light up display is easy to see.
    The hose isn’t real long but I can stand while airing up/down.
  7. #7
    Been Around the Block SLO's Avatar
    Jul 2016
    Portland, OR
    340
    This PowerTank inflator is by far the best I have used. They have digital and analog and this particular one has a 6’ hose. I have a drawer full inflators - ARB, Amazon, etc. This is all I use anymore. IMG_0604.JPG
  8. #8
    The Original Smartass piginajeep's Avatar
    Oct 2011
    Bear Valley Springs
    11,721
    I’ve had my Currie one like Eddie since 2004. Works great.
    2012 JK8
    1958 FC170 (Jeep Forward Control)
    1953 M38A1
  9. #9
    Nothing but a Thing danford.lau's Avatar
    Jan 2018
    West Los Angeles
    1,147
    I use arb and the digital psi read out has been very accurate . Maps exactly to the TPMS by 1 psi each time and all 4 tires are precise . Issue was with the shitty stock connector which constantly leaked or had to be held while filling up . Replaced with lock on chuck and has been so much better
  10. #10
    Fresh Catch Graeman's Avatar
    May 2019
    Phoenix, AZ
    4
    Quote Originally Posted by SLO View Post
    That is one beautiful setup right there. Very nice indeed..
Similar Threads
  1. Tire inflator
    By aldaman in forum The 8th Slot
    Last Post: 12-31-2016, 02:39 PM
  2. What pressure gauge do you use and why?
    By zimm in forum Jeep JK Wrangler
    Last Post: 04-17-2016, 12:59 AM
  3. Tire inflater gauge
    By branman in forum General Off-Road Tech
    Last Post: 11-21-2014, 03:20 AM
  4. Tire pressure help
    By shadow21 in forum General Jeep Stuff
    Last Post: 08-01-2014, 08:31 PM
  5. Low Tire Pressure?
    By bman198 in forum Jeep JK Wrangler
    Last Post: 06-15-2014, 02:22 AM
