Page 6 of 6 FirstFirst ... 456
Results 51 to 53 of 53
Thread: Engine Fire 2008 JKUR
  1. #51
    Hooked G-mansjk's Avatar
    Join Date
    May 2017
    Location
    Ca
    Posts
    144
    The only vehicle I've seen that calls for flammable coolant/ antifreeze in my time wrenching is a 54 international t340 crawler that calls for kerosene or ethanol for conditions under 40 degrees... everything modern from over the road to military calls for ethylene glycol and water mix on later vehicles.
    Quote Originally Posted by Noble Woodsman View Post
    This may be true in the case of military vehicles, but likely not relevant to this situation. Many military vehicles, such as those made by Oshkosh, utilize a single fluid for gear oil, engine oil, and i think coolant as well. This allows simpler maintenance in the field, but also means the coolant may be flammable. The antifreeze used in civilian jeeps is water-borne and not flammable.
    That's right I'm a window licker, I can't spell, my grammar sucks!!!!
  2. #52
    Join Date
    May 2017
    Location
    Ca
    Posts
    144
    I was a wrench for 5 years in the army and never saw anything other than modern coolant in anything besides air cooled engines like snowmobiles or atv's
    Quote Originally Posted by G-mansjk View Post
  3. #53
    Fresh Catch
    Join Date
    Mar 2014
    Location
    So. California
    Posts
    2
    My 2013 with 101k has a small gas leak next to the oil filter. The hard plastic tubing has several small cracks at the fitting to the fuel rail. I smelled faint odor of gas on start up. Nothing during driving...would smell again if stopped at stop light. I've found several threads with the same problem. Already tried to repair, but won't hold the pressure. I also question the integrity of the rest of the same old fuel line. Probably get an OEM fuel line rather than hoping it doesn't leak again.
Similar Threads
  1. RLN OVR - 2008 JKUR Build
    By Casey_250 in forum Member Jeep Builds
    Last Post: 03-28-2018, 11:24 PM
  2. Need replacement 3.8 engine for 2008 JK
    By Rugged Radios in forum Wanted
    Last Post: 10-28-2016, 10:08 PM
  3. NHTSA Investigates 2015 Jeep KL Cherokee Engine Fire
    By wayoflife in forum Jeep Cherokee & Grand Cherokee
    Last Post: 01-20-2015, 11:00 PM
  4. Uconnect in 2008 JKUR
    By Sharkey in forum Jeep JK Wrangler
    Last Post: 02-04-2014, 03:25 PM
  5. My 2008 JKUR all cleaned up
    By kRay.JK in forum Jeep Show & Tell
    Last Post: 07-03-2013, 12:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
