Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: How Far to Air Down
  1. #1
    Hooked JoeB-JKURX's Avatar
    Join Date
    Nov 2015
    Location
    Albuquerque
    Posts
    217
    How Far to Air Down
    So, I've got 17X9 Level 8 Bully Pro wheels (which claim to have an extra lip to help secure the tire on the rim). I currently run BFG KM-2 35X12.5 tires at 15 psi, on some pretty gnarly trails, and have never thrown a bead. Got 4.88 gears and am ready to go to 37. Considering STT Pros at 12.5 or 13.5 and wondering "how low can I go" and feel relatively secure I won't throw a bead on my next ledge or waterfall? Any suggestions will be appreciated and considered.
  2. #2
    Caught the Bug Fury22's Avatar
    Join Date
    Oct 2018
    Location
    Buffalo, NY
    Posts
    97
    I aired my 35in dick cepeks down to 10 or 12 on 16x8s and never had a problem. Just got 37x13.5 stt pros on 17x9s and plan on doing the same 10 to 12...
  3. #3
    Nothing but a Thing QuicksilverJK's Avatar
    Join Date
    Apr 2016
    Location
    Reno NV
    Posts
    1,404
    I run 37x13.5 STT Pros on 17x9 procomp aluminum wheels. I run 12psi on a regular basis, I have run 10 on occasion when the trail warrants, and have accidentally hit 8psi a couple times without ever popping a bead.
  4. #4
    Nothing but a Thing Saharaunlmtd's Avatar
    Join Date
    Feb 2013
    Location
    Pittsburgh
    Posts
    1,573
    Quote Originally Posted by JoeB-JKURX View Post
    I too have wondered about that extra lip and if it would allow lower pressures.
    Doesn’t seem to be much info on it. Does it work or marketing hype?
  5. #5
    Knows a Thing or Two A.J.'s Avatar
    Join Date
    Jun 2015
    Location
    Grants Pass Or.
    Posts
    955
    Quote Originally Posted by Saharaunlmtd View Post
    Nearly all wheels have that bead seat lip. They might be slightly bigger to help hold the bead but not much. Old Land Rover wheels had some that were raised quite a bit. They will scare the shit out of you airing them up the first time. When the bead finally seats they really pop! I think Interco had some that were raised a bit also. Ugly ass wheels though so hardly any sold.
  6. #6
    Join Date
    Feb 2013
    Location
    Pittsburgh
    Posts
    1,573
    Quote Originally Posted by A.J. View Post
    Yeah, it does look like other wheels which makes me wonder about their claim, “a specially designed bead hump to keep the tire on the wheel during your off-road adventures.”
  7. #7
    Nothing but a Thing jdofmemi's Avatar
    Join Date
    Mar 2018
    Location
    Menifee CA
    Posts
    2,291
    Looks like hype to me.
    I used to run 35-12.50 and 37-12.50 on 15x10 Ultra wheels. I would run 10 and sometimes 8 without too much trouble. I would get dirt and small rocks stuck in the bead sometimes that would cause slow leaks, but never blew a bead. I also drove accordingly.
    Not saying you would never loose a bead, and you should be able to air it up again if it happens.
  8. #8
    Join Date
    Jun 2015
    Location
    Grants Pass Or.
    Posts
    955
    How Far to Air Down
    They might it’s just hard to see in a photo. Stock car racing wheels like Bassets have the same thing. You will know when you air them up. They will snap on to the bead really hard. Use lots of slick or soap.
  9. #9
    Addict BaddestCross's Avatar
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,737
    My DC-1s (and 2) have the same. It's a bitch to get the tires off by hand and it took quite a bit of pressure from my nitrogen tank to set the beads.
    I can run down to 10psi with no problem. Haven't tried to go any lower since I have a split in my sidewall that worries me. 😂
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  10. #10
    Old Timer TrailHunter's Avatar
    Join Date
    Apr 2016
    Location
    SoCal
    Posts
    4,728
    Quote Originally Posted by BaddestCross View Post
    You would only have to change them half as much if you would just by New tires instead of used.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
