Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: JK overheating then not
  1. #11
    Guy with a Red 2-Door cozdude's Avatar
    Mar 2013
    West Chester, PA
    18,461
    Quote Originally Posted by longarmwj View Post
    Mines doing the same thing. It’ll go up to about the 3/4 mark on the gauge then go back down once the fan kicks on. Gonna try washing the radiator out to see if there’s any mud or anything gummed up there and go from there.
    This is a big issue. Most of the time it’s old mud stuck between the condenser and the radiator not allowing proper air flow to pull the heat out of the coolant. I’m sure you will be surprised as how much washes out.
    October 16, 2013, wednesday early evening, east of the pacific ocean, selectee for truly random and boring Parking lot photo of the moment grand platinum prize winner!
    2011 JK
    EVO Bolt-on Coilovers, EVO 1/4 pounder w/ stinger, 37" Cooper STT Pros, PR44, and some EVO stuff
    Awaiting install-
    On Order-
    Want list- Evo carrier and skins, PSC hydro assis
    jlwrangler.com
  2. #12
    Addict BaddestCross's Avatar
    Aug 2016
    Palmdale, CA
    5,051
    Mine was doing this when it got into the mid 70s outside. I flushed the cooling system, replaced with fresh coolant, and replaced the thermostat... So far no more issues.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  3. #13
    Addict jeeeep's Avatar
    Oct 2011
    Tx
    5,411
    I've been dealing with the same issue on my 2010. When running the AC and at 65mph, temperature would climb to the 3/4 mark until I turned the AC off and slowed down...temp would drop back to midpoint.
    I had the AC compressor checked and even though the AC was blowing cold, it was low. They put dye in the system and haven't had issues since getting the AC done but I still need to take it back to check for leaks.
    I suspect my water pump may be failing as well.
    I replaced the thermostat and housing at a hotel parking lot due to a pinhole in the housing but when I refilled the radiator it appeared to not have a constant flow.
  4. #14
    Been Around the Block RCVRY's Avatar
    Jun 2017
    NWI Region Rat
    412
    I’ll just throw this out there, try “burping” it uphill with the radiator cap off. It’s an old trick on atv’s that works but I’ve never burped a coolant system without the radiator standing tall without success. Cozdudes right about the air problem.
    If it persists it may be a leak, check your therm gasket or maybe head gasket ☹️
  5. #15
    Been Around the Block Bustedback's Avatar
    Apr 2015
    NorCal
    340
    There’s a bleeder screw on the thermostat housing on the 3.6. You have to remove the throttle body in order to get at the screw. Open the bleeder and remove the cap, when you get coolant flowing from the bleeder, close it up and top off the radiator.
    Typed by my very own fat fingers on my iPad or iPhone.
  6. #16
    Jun 2017
    NWI Region Rat
    412
    Just thinking, if it’s fine after burping but then overheats after sitting you’ve definitely got a leak.
  7. #17
    Fresh Catch
    Jan 2015
    San Diego
    3
    I had the same issue. I replaced the fuse, thermostat, and flushed the radiator. Then it overheated again. I found the negative battery terminal was slightly loose, not even enough to move it by hand. Tightened it up and haven't had any issues since. The terminal was loose enough to prevent the fan from turning on.
  8. #18
    Been Around the Block Gbint's Avatar
    Dec 2017
    Victoria B.C.
    496
    Us old mechanics jack up front of vehicle about a foot, so rad cap is highest point of system. Run until cooling fan kicks in. Put cap on after topping up before letting front end down.
    if it ain't broke!
Similar Threads
  1. Overheating
    By BlackJKU08 in forum Jeep JK Wrangler
    Last Post: 07-20-2017, 06:30 AM
  2. Overheating 3.8
    By Lmoye22 in forum Jeep JK Wrangler
    Last Post: 10-08-2016, 06:44 PM
  3. 08 jk overheating
    By Bmans08jk in forum Jeep JK Wrangler
    Last Post: 08-16-2016, 09:57 PM
  4. Overheating when AC is on
    By seanb123 in forum Jeep JK Wrangler
    Last Post: 08-24-2015, 06:19 AM
  5. JK overheating
    By jorgelrod in forum Jeep JK Wrangler
    Last Post: 12-23-2014, 01:44 AM
