Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Nsg 370
  1. #1
    Fresh Catch Joeyd94's Avatar
    Join Date
    Feb 2018
    Location
    NY
    Posts
    29
    Nsg 370
    Any ideas on what I can use to get the 17mm hex nut out of the transmission the exhaust is in the way. Image1557191505.654954.jpg this isnít fitting because of the exhaust.
  2. #2
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    28,722
    What hex nut are you trying to get out? What's the nut for?
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  3. #3
    Caught the Bug Fury22's Avatar
    Join Date
    Oct 2018
    Location
    Buffalo, NY
    Posts
    97
    Quote Originally Posted by WJCO View Post
    Iím guessing heís trying to change his transmission fluid...
    I ended up finding a 17mm bolt put 2 nuts on it and cut the excess bolt off...worked well
  4. #4
    Knows a Thing or Two Wethy's Avatar
    Join Date
    May 2014
    Location
    Ontario
    Posts
    725
    Eddie has a good write up on this but you can go to lowes or a hardware store pick up a 1/2" threaded rod coupling and grind down one side to fit the 17mm hex key and leave the other side and use a 3/4" wrench on it. Works like a charm and ive used it twice now. I do believe you also have to shorten the coupling some as well but its handy to have and easy to get/make
    Edit : Heres the project jk write up link
    https://project-jk.com/jeep-jk-write...ission-service
    Sent from my SM-G960W using WAYALIFE mobile app
    '14 JK Sport Anvil 6-Spd 3.73 gearing
    Installed:
    -Rubicon Express 2.5" lift with monotube shocks
    - Cobra Cb 18 WX STII
    - 285/70/17 Duratracs
    - 1.5" G2 Wheel Spacers
    - Rigid Dually Spots
    - Poison Spyder A-Pillar Mounts
    -RC 2.5" swaybar disco's
    Awaiting Install:
  5. #5
    Nothing but a Thing desertrunner's Avatar
    Join Date
    Mar 2013
    Location
    Great Falls, MT
    Posts
    2,123
    As mentioned before Eddie has a good write up but cut like a 1.5" section of it off and duct tape it to a wrench and wedge it in there. That's what I do at least
    12' 2dr Gecko Sport 6 speed
    PR44, ARBs, 4.88s, 35 spline rear, Adams 1350 Front & Rear, Rubi T-case, Rubi sway bar + Evo no limits, Evo armor & skids, 37/13.50" Cooper STT Pro, Evo 2" plush / OME med duty springs
    ***SOLD*** 08' JKU Rubicon 6-speed Stone White, 3.5" RK lift, 37" KM2s and lots more.
    ***CURRENT DD*** 16' F150
  6. #6
    Caught the Bug Jkjon's Avatar
    Join Date
    Sep 2013
    Location
    Texas
    Posts
    50
    Nsg 370
    You should be able to take a punch/hammer and literally knock that 17mm hex portion out of the chrome socket and just use an open ended wrench on it to back out the transmission plug.
  7. #7
    Join Date
    Feb 2018
    Location
    NY
    Posts
    29
    Quote Originally Posted by desertrunner View Post
    How did you cut through it?
  8. #8
    Join Date
    Feb 2018
    Location
    NY
    Posts
    29
    Quote Originally Posted by Jkjon View Post
    Yeah Iíve been trying that seems pretty wedged in there. Maybe Iíll give it another go
  9. #9
    Been Around the Block Ruvicon's Avatar
    Join Date
    Jun 2017
    Location
    Turlock, CA
    Posts
    330
    Nsg 370
    Another option would be to find a bolt with a 17mm head (or slightly larger and grind it down) and bend it like this one. Off the top of my head, donít know how much clearance you have to work with. IMG_8830.JPG
  10. #10
    Knows a Thing or Two -AINOKEA-'s Avatar
    Join Date
    Oct 2011
    Location
    Hilo, HI
    Posts
    705
    I didnít have a way to cut a piece so I ordered this guy off the interweb. Pricey for what it is but at least now I have it. Worked like a champ.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
