The home screen between the gauges is stuck. Every once in a while the top right corner reads 800*.
Also, every now and then the radio will shut down or change from SXM to FM after about a minute being on.
Anyone else experience this?
On The Trail Comment... sent via Morse Code
You should probably stay away from volcanoes.Made an appointment today at the dealership for May 23rd.
The 800* thing came back today. When you go to the screen set up, it doesn't list what it is. Very weird!
View attachment 326684 View attachment 326685
Not bad, you just have to make sure you have good ceramic infused tires and a fire blanket for overnight camping.Is there any good rock crawling down there in Hell [emoji23]
Will do... thanks for the heads up.I hope you get it sorted out quickly. If the radio doesn't remedy the situation, be sure they check out the HVAC control panel that includes the radio control knobs on it.
Nothing so far.Anyone had a problem with the electronic steering yet?
